Washing Machines Logo
Posted on Feb 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We purchased a home with a Maytag Legacy washer that is about 4 years old. Our alst load it smelled like something was burning so we unplugged it and are thinking of purchasing a new one. It is not the belt but smells more like burning plastic, do you ahve any idea what that may be?
Anonymous
Level 3:
  • Master 714 Answers
  • Posted on Feb 21, 2010
Anonymous
Master
Level 3:
Answers
714
Questions
Helped
188962
Points
2163
Motor coupling ,,,cost about 15 bucks
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
1helpful
2answers
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
White smoke coming from the machine, it was in the middle of the extended cycle. stopped machine and unplugged. Smells as though something burned.
Usually the first repair a Maytag washer needs is to replace the belts. They can wear out and smell.
The belts are located on the very bottom of the machine. They are not covered. If you pull out the washer about 2 feet and lean it back against the wall you will see the belts on the bottom.
If they have shiny parts, or one of them was sticking. You will be able to see if it is burned.
I've made a diagram to help.
The "main drive pully" is the belt that is most likely to be burned. It is also possible for a clothing item such as a baby's sock, to get caught in the pump. That being the case, the pump belt can burn.
If you replace the belts, which you should do if the machine is 10 years old. You must replace them with Maytag belts. This is important, because they are designed to allow some slippage. If you replaced them with belts of the correct size but not the right type, the machine will not work properly.
Of course, the machine can have electrical problems, but it is rare. Let me know what you find and I can advise you further. Happy New Year, Mark
I have a Maytag topload 1412 series 4. I recently tried to wash a comforter far too big for it. About ten minutes into the first cycle I checked on it and smelled something burning. I did not see any...
lo mas combeniente en estos casos es revisar el bobinado del motor obiamente esta quemado pero puede ser renplasado por un motor nuebo instalado por un experto en la materia
Burning smell when my Maytag top load washing machine is running
Sounds like the belt is sliping. ether it's loose, or the trans needs lubed, or both.
Maytag washer top load
hi thanks for the question i think you could have a problem with your tub bearing or you could have a piece of clothing caught between the tank and tub remove the front lift up the top remove the plastic top and look you will see if you have something caught in the space between those two pieces thanks the appliance doc
Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
