There could be a few different reasons why your keyboard is stopping recording after a minute. Here are a few things you can try to troubleshoot the issue:
Make sure that you have enough free space on your device to save the recording.
Check to see if there are any other programs or processes running on your device that could be causing the issue. If you have other programs open, try closing them to see if that helps.
Try turning off any antivirus software you have running on your device, as it could be causing conflicts with the recording process.
Make sure that your device is updated to the latest version of its operating system.
If you're using a digital audio workstation (DAW) to record, make sure that you have the latest version of the DAW software and that it is compatible with your device.
If you've tried all of these steps and you're still having trouble, it's possible that there could be an issue with the keyboard itself. In this case, you may want to try contacting the manufacturer for further assistance.
Are you trying to use the mic input on the back or plugging it into the instrument input on the front? If you use a low impedance mic with a quarter inch instrument input cord, you would need a transformer adapter to make the mic work on high impedance. Even if you put it on line in, you would still have to convert it. Only the XLR socket on the back will work on a low impedance mic.
It is likely you do not have the levels set correctly and are over driving the mixer. Reduce the trim settings using the PFL buttons and monitor the level indicators to insure you are not clipping.
With a condenser mic you CANNOT have any speaker in the room that the mic can hear of course. These mics are so sensitive. Your mixer and monitor speakers and recording will be in a separate room from the soundproof studio typically.
To monitor the system anywhere in the same room as the mic you MUST use headphones that do NOT leak sound or you will get feedback and distortion.
Sorry, but the Lexicon Alpha does NOT have Phantom power and you can't use a condenser mic with it without a Phantom power injector or preamp.
If you mean you have a Phantom power injector then it should be working. Do you have seperate mics for the two channels of the stereo? If you have only one mic, then only one side will record unless you set for mono recording and then dump the recording into stereo voa Cubase. I would recommend you get a small mixer... even a 4 channel one to use ahead of the Lexicon so you can mix and PAN your mics the way you want them. The recording and trying to control the panning in Cubase can be frustrating... The Lexicon really doesn't have anything built in to PAN the mic to the center when stereo recording. Small mixers are inexpensive and often you can find them used or in pawn shops for cheap.
Yep ! First thing is to eliminate any processing resource "hogs" that **** respources and can cause buffer overruns. Eliminate Antivirus, antispyware, and network communication and wireless network programs running in the background while recording.
Next make sure that ALL equipment is powered from the same receptacle or power source. In your case that should be the mixer and the PC.
Next remember that the condenser mic picks up everything... I have 5 of those mics and seemingly noise free environments turn out to have little things that generate fast rising pulses that you don't notice till they are recorded.
Lastly, the air here is very dry and plain old static electricity is rampart... Lady shuffling her feet was sending pulses through the mic cable at our church. They are NOT audible until they get into the sound system as clicks.
I have found that trying to record directely to a USB stick often has ooverruns and clicks... also burning a CD from stick to the CD results in noise due to buffer underuns. Burn from Hard drive to CD and make sure all the other hog programs are shut off.
I don''t think you can solve this problem. The problem is that the computer has to digitize the incoming audio, then echo it out. This conversion takes time and is also governed by the real time clock servicing of the devices. You could try upping the priority of the conversion process, but I don't think you are going to be satisfied with the result either.
You would be happier to use a mic and external mixer where the audio is true real time rather than having the conversion latency time.
Whichever works best for you is best. You can always lay down a scratch track for each like this and then lay down another track to replace whatever you didn't like using the scratch track as a guide. Erase the scratch tracks that you don't need before you mix down. I hope this helps.
While this is Mac-related, the information regarding the reset button is helpful and seemingly little-known. This comes from a Korg rep, by the way:
Did you first manually eject the drive from the Mac before disconnecting it by either moving the drive into the trash or using the Eject option from the Finder menu? If you try to exit USB mode without ejecting the drive on the computer first and then disconnecting the cable, this can cause the unit to lock up. Additionally, you’ll notice there is a tiny hole below the volume controls on the side of the unit. You can use a paperclip to push in a button within this hole to manually reset the recorder however this is only recommended in extreme circumstances. Look forward to hearing from you.
-Matt
