ASUS M4A78T-E Motherboard with AMD Phenom II X4 955 Quad Core Processor Bundle (M4A78TEX4955BLACK) Logo
Posted on Feb 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set asus montherboard bios
How to setup asus Montherboard bios. also how to setup a graphics card and setdown onboard graphics in bios..
Anonymous
Level 2:
New Friend:
  • Expert 91 Answers
  • Posted on Feb 22, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
91
Questions
0
Helped
35145
Points
175
Keep pressing del as u start the pc u will see the bios
as far as GPU is there u can do it from the bios for overclock related thing and for other thing u can do it using the windows
I actually have the 512mb graphics card but my question is how do i install graphics drivers when the installation disc wont even do a complete install?
unplug power cod, open computer Cabinet panel, remove cmos for 2 min and reinsert cmos,
wipe graphics card socket, reinsert graphics card, TURN on computer, press f2 to load default setting
you do not need to disable onboard graphics. in bios, some bios default configure your graphics card to primary
hope will help you
NO ONBOARD VIDEO
Hello here is the ASUS homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5N73-AM&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Your pci-e graphic card is failing or has a defect.
The problem could also be the power supply, not giveing enough power.
When you add a pci-e graphic card on the mainboard, the onboard graphic should deactivate itselves.
Try to remove the pci-e graphic card, and use the onboard graphic.
If still no picture, change the power supply.
Its not possible to change settings in the bios blindfolded.
You can reset the bios by removeing the cmos battery.
But ofcouse it could also be the mainboard itselves failing.
This is rarely happening, so i hope its just the power supply.
Try also to look for visual defects on the mainboard, especially the condensators on the mainboard.
Good luck
Scaleo p fitted new graphics card asus geforce 210 wont start up
Hi , i suggest try running the driver setup in "custom mode" checking option : clean install , to remove previous possibly corrupt installed settings
Also access BIOS setup and change "first seek peg" or some such, so BIOS communicates to Windows to first seek video device expansion card rather than onboard
(ps , if changed from onboard to expansion card ensure the onboard control applet for onboard video has been uninstalled via add/remove)
Trying to install ATI FireMV 2400 256mb pci-e card. I have a new pc with asus m4a78lt-m motherboard, athlon x4 645 3.1ghz processor, 3gb ram, windows 7 32 bit os, 500w psu Card installed in pcie x1...
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
I have a problem! I instal the windows and i don't know the name of my video card, the video card is integrate in montherboard. The montherboard name is Micro-star MS 7211!Please help me, and i'm sorry for...
Here You can find all drivers to your motherboard:
There is a 4 in 1 which includes video drivers - but there is also some other which I can recommend you to install to get sound and so on working correctly.
http://eu.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=234
1helpful
PCI-E card does not work, onboard video works fine, this is the second card.
The Abit IP-95 manual doesn't show you how to adjust your bios settings when adding a PCI-E x16 graphics card. When adding a PCI-E card you'll need to adjust a few settings within, Advanced Setup.
Press the delete key on your keyboard every two seconds to load your bios menu. Within Advanced Setup look for, Onboard Device Configuration and open it. Find, Primary Graphics Adapter.
Set this to read as [PCI-E, VGA] save your changes and exit.
Currently your onboard graphics is enabled. You'll need to change this setting to PCI-E first. When you use the onboard UniChrome Pro 2D/ 3D Graphics & Video Controller you are also using some of your system memory to run the UniChrome graphics. Once you enable the bios to boot to the PCI-E card you can also stop using your system memory assigned to the UniChrome card. Link to Abit is provided below, click on it to open;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=IP-95&fMTYPE=LGA775
Cheers!
Mike
1helpful
2answers
How do I reactivate my onboard video on my mobo ? (Asus A8V-MX-UAYKZ)
It will automatically be activated if you remove your Graphic Card
No signal problem with xfx 9400gt fatal1ty
Check for bios jumper set for normal operation, check for onboard vga jumper set for pci or external video.
1helpful
2answers
Asus memory
Yes you can buy a new MB. Here's a link to a motherboard that will support 4GB or RAM. You didn't specify what proc you have to double check to make sure the MB is compatable.
Replacing the onboard graphics card
Friend,
There are three PCI slots on yoyr motherboard. You can add any PCI VGA card to your board. After adding the VGA goto BIOS setup and make ON BOARD VGA DISABLED.
Thanks & Good Luck
Iqbal
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
