I'd like you to look at this motherboard, and compare it to yours.
It's an Intel Seabreeze T3 motherboard. My data states it was used in many computers, and the eMachines T3830 being one of them.
http://support.gateway.com/s//MOTHERBD/Intel2/2521776/4000979nv.shtml
On this page left-click 0n - Product Views, in the list.
On this page left-click on Q-Front Panel Header.
You have three twisted pairs of wires coming from the Front Panel of the computer.
One pair is for the Power On switch. (PWR, or SW, or SW1)
One pair is for the Harddrive Activity Lamp. (HDD LED)
One pair is for the Power On LED light.
IF, my information is correct, the Front Panel header on your motherboard looks like this,
http://support.gateway.com/s/MOTHERBD/Intel2/2519274/2519274mvr20.shtml
4 pins going across the top.
5 pins going across the bottom.
Notice although across the top is shows 2, 4, 6, 8, and 10, (In Red), there is No pin 10. Just a blank spot.
Pins across the Bottom starting from Left going to the Right, are
1, 3, 5, 7, and 9.
Pins across the Top starting from Left going to the Right, are
2, 4, 6, 8.
No pin 10.
1) Pins 1 and 3 are for the Harddrive Activity Lamp. (HDD LED)
2) Pins 2 and 4 are for the Power On light. (PWR LED)
3) Pins 5 and 7 are for the Reset switch. (RST)
4) Pins 6 and 8 are for the Power On switch. (PW1, or PW SW, or SW1, or PWR ON, or ATX-SW)
5) Pin 9 is for the +5 Volt power
This is eMachines Support, and NG3 Hardware Reference Guide.
You may also find it useful.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3830
Should this not be the motherboard, let me know in a comment.
You must check cable(small) one the (left or right) one hard drive, CD Drive, floppy disk and for motherboard (the big one) .You check the manuals, is not hard just follow where the power lines.
SOURCE: Motherboard Config Emachines T2984
I have been tried to power up this emachine T3958 but no such luck. I accidently pulled the PWR S/W, HDD Led and PWR Led for the hard drive and I dont know how to replace the wires on the motherboard . Can't find a system board diagram online. Does any one know how the connectors fit on the motherboard?
SOURCE: power switch wiring
Locate your battery on the motherboard. It should be near the edge closest to the front of your machine. Look along that edge for a two or three contact header (connector with stiff gold plated wires sticking straight up). Near the header you will see in very small white writing "PWR SW". That's it. If it isn't on that edge, continue looking along the edge closest to the bottom of your machine. It i along that edge on some boards.
SOURCE: Need correct MOB location for power switch on emachine W3410.
what kind of motherboard did you change..?
try to search in the internet.. just type the name of the board and including the diagram.. sample.."ASUS MOTHERBOARD POWER DIAGRAM"...
SOURCE: EMachines Power Switch
Rather than hunt for a diagram, take a metal conductor and short out the prongs two at a time until you find the two that turn on your PC. It is 100% safe to do this as you CANNOT damage the motherboard by shorting out the wrong prongs.
Best wishes,
Graemevm
SOURCE: need replacement wires for a emachine T6410 for
You may contact Live-Tech 1-888-361-8511 they can assist with the order of the parts and installation. If needed a tech can be sent out to do the repair for you once you get the needed parts. Please explain your problem in more detail it is not common to have such an issue.
