Question about YDI Wireless Extended Range 802.11b Access Point (ap-ant)
I have a YDI Agere Systems AP-ANT-LR. I lost my password and need to reset it. It does not have a button to push and hold down to reset. Instead the resets are magnetic. I have used a magnet to light all the lights red and have held it for up to 2 min and still no dice. What can I do or get to make this work?
2 Suggested Answers
SOURCE:
pontelemon
  • 538 Answers
SOURCE: YDI AP+
Press reset button and hold or 10 seconds.
Posted on Mar 20, 2009
Can my son's forgotten password on his Zeiki tablet be manually overriden?
You have to reset your tab its at the back of your tablet .or you may go nearest service provider to unlock it.if is not working go to unlock account enter your user name then choose pattern enter your new pattern and then enter it again for confirmation..or u shut down the device then hold the power button hold again the volume up and the power button together.you see the recovery mode scroll down the with volume down button press the factory settings using the power button..then press the power button again to reboot make sure your battery is fully charge.
Apr 25, 2015 | Tablets & eReaders
Ydi ap plus won't reload factory defaults
Try This:
    • 1 Unplug all cables from the router except the power cable. Power on the router.
    • 2 Locate the reset button. This is typically a small hole marked "Reset."
    • 3 Insert the straightened end of a paper clip or the point of a ballpoint pen into the hole. Press and hold for about 10 seconds. Lights will blink, indicating that the unit is rebooting.
    • 4 Refer to your user's guide and follow instructions on setting up a new router.
Aug 01, 2012 | YDI Computers & Internet
3com AP 7250 - how do i reset it to factory defaults if i don't have the admin password ?
It will have a reset button on it, hold it down for ten seconds and it should reset the router to factory.
Mar 12, 2012 | 3Com Wireless LAN Access Point 7250...
Lost password,after reset (pressing for 5 second), admin/admin failed to log . Pl advice.
Some engenius wireless access points do not have a username password configured by default, so try it with the username and password fields both blank.
Sometimes, I have tried to reset the password on a wireless access point, and later figured out that I had failed to successfully reset the device. Make sure that the device is plugged in while you hold down the reset button. Hold down the reset button for 30 seconds instead of 5.
May 08, 2011 | EnGenius EAP-3660 802.11b/g Wireless...
Hello have 2 Proxim ap orinoco 4000MR-LR Outdoor and i forgot all password and disable hardware reset how can I reset device to factory default
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
There a great article at General Router Setup.
Jan 31, 2011 | Proxim ORiNOCO AP-4000 (8670MUS)...
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
Tut systems Expresso MDU Lite-LR. Lost password--need to set to factory defaults
There should be a pin hole switch at the back of the concentrator, to reset the unit to factory setting.
Try pushing the pinhole reset switch with a pencil for ten second. If that does not work , unplug the unit from power, and hold down the pinhole with a pencil while connecting power and starting the concentrator at the same time.
After resetting the concentrator you will have to enter again settings.
Jul 24, 2009 | Computers & Internet
Have problems connecting with my ISP
right click on my computer and got to manage. then there click on the driver u want to update, click on update automatically.
if it not help then visit:
moz-screenshot-3.jpghttp://tinyurl.com/m7ghqz
Jun 15, 2009 | HP Compaq Presario SR2011WM PC Desktop
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Here are the steps to reset the access point from D-Link's website:
Please visit http://support.dlink.com/faq/view.asp?prod_id=1600 for complete FAQ and screen shot.
The following reset procedure will completely restore the default settings on the access point including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the access point powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
You can find the complete manual for your wireless access point here:
http://support.dlink.com/products/view.asp?productid=DWL-2100AP
Mar 15, 2009 | D-Link Computers & Internet
YDI AP+
Jan 23, 2009 | YDI Wireless Extended Range 802.11b Access...
YDI Wireless Extended Range 802.11b Access Point (ap-ant) Logo
Top YDI Computers & Internet Experts
Alun Cox
k24674
Are you a YDI Computer and Internet Expert? Answer questions, earn points and help others
