1) Lube the deck belt use 100% silicones or wax, read your instruction manual
2) Lube the rollers bearing use wd-40
3) Replace fuse and see if is o.k now
4) If the problem persist you must test the tension for drive belt motor, and adjust it according.
5) Test the input voltage motor, see my personal TIPS for motor help and troubleshooting.
6) Use the treadmills directing from the source DO NOT USE any extension power cord!
7) Test again if the problem persist,now you have power supply or control board faulty. see the block diagram.attached.
God bless you
