Kitchen Appliances - Others Logo
Posted on Feb 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to wire up an E40 ceramic lamp holder for use with compact flurescent (sic) or high intensity discharge lights? (GENERAL ELECTRICAL KNOWLDEGE) Lights are used in factory High & Low Bay lighting; Outdoor Sports Flood Lighting; Shop Fitting & display; and Indoor Gardening
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Feb 21, 2010
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1093056
Points
9665
If this is being used as a socket for a 120-volt lamp (such as a compact fluorescent with self-contained ballast or an incandescent lamp), you wire the black (hot) AC line conductor to the brass-colored screw and the white (neutral) conductor to the silver-colored screw. If the socket is equipped with pigtails instead of screws, use pressure connectors (wirenuts) to connect black to black, white to white.
If you are using HID lamps, you don't wire directly to the AC line. These lamps must be used in a fixture with the correct ballast transformer, capacitor and ignitor (for pulse-start lamps) for the lamp wattage. If you are replacing the socket in such a fixture, follow the wiring of the old one when installing the new socket.
Passenger side headlight does not work on 2007 Pacifica. .
are you DIY, doing or did this work or others?
your hands? if did, see the HID bulb below?
head light , right side, dead (USA right side) ?
in UK passenger is LEFT side. so please say left /right
  • low beam
  • high beam
  • and high beam flaster switch
OR all 3 dead. selections dead.
and all other electric things work and car drives ok.
yes the 2 orange are parking lamps. all sides/corners and ends of car good parking lamps.
off hand using the wrong bulbs not reading the free users guide in the glove box for bulb number
USA answers only (me)
Chrysler maker
this car uses the BCM body brain to run front lamps
and does so using 4 outputs. 2 low and 2 high each side.
some of these cars have HID lamp options.
and are totally unique, for head lamps! IF TRUE.
standard bulbs are H3 TYPE. AND ARE NOT HID.
PAGE 406 IN THE USER GUIDE
HID BULBS ARE HIGH VOLTAGE LAMPS.
DO NOT PLAY WITH THOSE, OR GET SHOCKED
AND REQUIRE SPECIAL PARTS TO REPAIR IT.
Same page
On vehicles equipped with High Intensity Dis-
charge Headlights (HID), when the headlights are turned
on there is a blue hue to the lights. This diminishes and
becomes more white after approximately 10 seconds, as
the system charges.
the lost free manual is here by maker
https://vehicleinfo.mopar.com/assets/publications/en-us/Chrysler/2007/Pacifica/1577.pdf
and more
Do not touch the glass of High Intensity Discharge (HID) or halogen bulbs with fingers or other possibly oily surface. Reduced lamp life will result.
HID install 1 step says
Place the igniter on the HID lamp. Do not at this time connect the igniter electrical connector. It will make it unable to twist the igniter to the closed position.
the igniter can be bad.
HID uses D2S bulbs only .
Chrylser p/n
MOPAR 4865941AB
and looks like this.
VERY EXPENSIVE TOO. PARTS.
hid-undefined-undefined-0_0.jpg PARTS PAGE
https://www.rockauto.com/en/catalog/chrysler,2007,pacifica,4.0l+v6,1433518,electrical-bulb+&+socket,headlamp+bulb,11701
Can I wire 3wire bulb holder into 2wire bulb holder for signal light.
Yes, one wire is ground, one is high intensity the other is low.
What is an HID lamp?
High Intensity Discharge is just like the big lamps you see on the streets and in industrial lighting. HID lamps require ballast which is an expensive material and can't be found in every local hardware store. Furthermore, the HID consume lots of electricity and can draw lot of power therefore their operation is also expensive.
Aug 21, 2012 • Fish
How do I get the strobe light on the Mobilite 300 to stay on continuously?
You can't get the strobe light to stay on continuously, the strobe is a very high voltage discharge lamp which can only illuminate briefly.
But the unit does have a built in modelling lamp at far lower power and intensity, used only to set up the lighting rig and to check for shadows and highlights. As long as the unit is connected to mains voltage then you just use the power switch to turn the modelling lamp on.
Oct 07, 2010 • Cameras
Polo 1.9 tdi left head light not not working, fuses okay, bulb on its own works what could the problem be
hi, there is a relay for head lamps. if you check the revse side of the fuse cover. (looks like a basin on its side with straight lines forward or diped lines) if this not the problem the wire suppling the head lamps is broken or loose or very bad connection or dirty. also check the earths around the lamp. a volt meter or a lamp holder with lamp and lenght of wire one with a clip and the other with a probe can be used for general testing and checking electrical systems/ gerry
How do i change a brake light bulb on 2000 vw jetta?
Removing:
  • Switch off all electrical consumers, switch off ignition key and remove ignition key.
  • Remove rear luggage compartment side panel trim (left or right).
  • Remove 3 nuts, arrows, and remove housing.
  • Remove bulb holder.
Installing:
  • Install bulb holder.
  • Insert housing into body opening.
  • Tighten nuts.
  • Install applicable rear luggage compartment side panel trim.
Rear Light Bulb Holder Removing And Installing:
Removing:
  • Disconnect electrical connector.
  • Depress retainers, arrows, and remove bulb holder.
98971817.gif Installing:
  • Install in reverse order of removal.
And the Center Mounted Brake Lamp.
High mount Brake Light Removing And Installing:
The high mount brake light is installed in the rear shelf.
98971288.gif Removing:
  • Disconnect electrical connector from high mount brake light.
  • Remove rear shelf
  • Un-clip high-mount brake light from rear shelf, arrows.
NOTE: The bulb holder base plate contains soldered- in light emitting diodes (LEDs) that are not replaceable. In the event of LED malfunction, replace complete bulb holder.
Additional
Where is bulb located
The lamp assembly is usually housed in a metal holder which can be located behind a removable cover at the rear of your set. The lamp assembly is a high intensity halide lamp with integral parabolic reflector unit. Some later models permit user access to lamp holder via an access cover, earlier units required access to the set's internals by qualified personel.
4helpful
2004 Lincoln Navigator Low Beam Bulb replacement
your owner manual will list the bulb. It is expensive. tascafordparts.com for discount from Ford Dealer
here's 2003, don't have 2004
Navigator high intensity discharge (HID) headlamp
  1. Remove the front radiator air deflector.
  1. Remove the three bolts and the headlamp assembly.
    • Disconnect the electrical connectors.
8. Remove the headlamp bulb protective cover(s).
  • Remove the HID lamp cover.
  • Remove the high beam cover.
  • Disconnect the electrical connector and push the grommet into the headlamp assembly.
  1. Release the spring tabs and remove the HID low beam bulb.
Top Kitchen Appliances - Others Experts
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
