Radio Communications Logo
Posted on Feb 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Icom VHF that was hooked up reverse polarity on 12v.
I have a newer Icom VHF Marine radio and hooked it up to 12v with reversed polarity. I took it to my local electronics repair shop and they charged me $150.00 to repair it. What did they do?
Anonymous
Level 3:
President:
  • Master 2,761 Answers
  • Posted on Feb 27, 2010
Anonymous
Master
Level 3:
President:
Answers
2761
Questions
Helped
934188
Points
7369
They likely replaced just about every diode and possibly the main circuit board. The tech should be willing to tell you exactly what work was done, and many return the replaced parts.
Why my icom 2200h is getting hot even if i did not used it and when the power is off?
Check your wiring , you may have reversed the power suply with the stan by wires. They are both same polarity, hoever the power goes to fuse and control panel and the standby gos to baterie.
I need amounting brack for my icom ic m302 vhf marine transceive where can i get it
Try Ebay as a source. I have had good luck finding such accessories for reasonable.
Polarity reverse problem in icom 706 mkiig
Quite a few things can go wrong in this situation. There is an internal fuse that can blow, but the first problem will be a rather large diode that is directly across the DC power input. Reverse polarity will cause this to short, and it usually stays shorted. It will need to be replaced. Then, you should look for open traces from the +12V line to the fuse holder, and the collector of the HF output transistor. If you do not see close to ZERO ohms when your leads are attached, then you have a trace blown off the board.
Depending on how long you left the reversed power on, and if you replaced the inline fuses with a larger value, repair cost can run you from $2 to several hundred, just for the parts! I would take it to someone that knows how to work on this radio. It is not an easy radio to work on.
Icom ic-m35, no transmitting
Contact the Icom service center. Their main web-page is www.icom.com. From there you can select your geographic area and service (commercial, marine, amateur, etc).
Not transmitting
Contact ICOM service at www.icom.com, or take it to a marine radio service center.
2answers
I have an ICOM IC M505 marine VHF which is the closest model to the one described below. It is less than 3 years old. The channels have been very quiet including channel 16. This prompted me to test the...
Probably not the squelch but the speaker on the VHF. These radios are famous for crapping out when getting wet.
Try listening to the weather radio VHF ch 01, 02, or 03. depending on your location and play with squelch.. Keep in mind they do make external speakers you can hook up.
I have a Philips GPS Dantronik Navigater MK9 an now a Northstar VHF Marine Radio Explorer 710. I want to connect both over NMEA to get the position form the GPS to the radio. There are 7 different...
I connected my ICom using the NMEA in. I had the leads reversed first time, moved them around and worked. This was a connection from Furono to iCom but should be much the same
Jun 01, 2010 • GPS
1helpful
IC-M302 VHF Marine Radio: need to have wiring schematic coming out the back ...
Blue: Speaker (+)
Gray: Speaker ( -)
Yellow: NMEA IN (+)
Green: NMEA IN (- )
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
I have an icom m304marine vhf with a shakespeare
Sound like you have an antenna issue. Try a different antenna with coax. If the problem is still there, than you have a problem with the radio. Icom makes really good marine radios but you could have a defective one.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
