Yes your batteries have dropped below 9 vlt each and they wont chage using your charger. Yuo must take a car battery charger and charge each battery up to at least 11vlts for your charger to charge! This ought to work if batteries have only been sitting a couple of mths . When using a car charger set charge at 6-10 amps for about 45mins to 1hr then hook up chair charger and you should be ok
Well maybe your charger is faulty or when you used " alot of force " to push it in to the little hole it has to go in to charge it has moved it , if so then you will need a charger pack. but before you do anything try to get a new charger , Hope i helped :)
