Question about Exercise & Fitness
Life Fitness Treadmill "FET" error
I just received a new "board" for my Life Fitness treadmill. It worked fine for about 15 minutes then said "running error" and now is displaying FET error. Any ideas on how to fix?
  • Anonymous Feb 20, 2010
    T7-i
  • outfield502
    outfield502 May 11, 2010
    first that treadmill model you have? which is the card you just replaced? need to know this since you say the message appears on the screen, FET is an electronic component. send me information to my email: my name is Elias cardiotech_me@hotmail.com
    New Friend:
  • 16 Answers
Can you please provide model of unit.
Posted on Feb 20, 2010
SOURCE:
Error fet
haga un RESET de la maquina . Recomiendo que Corra el Software calibration for facil diagnostico y reparacion que viene con la maquina. lea su manual de instruciones. or bajelo de
www.fitness.manualsonline.com
Dios le bendiga.
Jun 19, 2013 | Life Fitness T5-0 Treadmill Fitness...
What does FET Error mean on my treadmill
Fet error is caused by the drive component(s) on the motor control board going open circuit or faulty. This is caused by poor power supply or excessive friction on the running belt which in both cases leads to excessive heat build up in the control electronics.
The Motor controller will need to be repaired or replaced and the heat issue resolved.
Apr 18, 2010 | Life Fitness T3 Treadmill with Advanced...
Error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Jan 13, 2010 | Life Fitness T3 Treadmill with Advanced...
FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
Nov 08, 2009 | Life Fitness T3 Treadmill with Advanced...
Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
Life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Feb 28, 2009 | Life Fitness Remanufactured Next...
Exercise & Fitness Logo
1,367 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
