Broderbund Print Shop Deluxe Version 22 Printshop 4 CD Box Set  Logo
Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought new computer. Cannot download my printshop
Bought new computer. Cannot download my printshop 22. I have Windows 7.
Anonymous
Level 2:
  • Expert 90 Answers
  • Posted on Feb 20, 2010
Anonymous
Expert
Level 2:
Answers
90
Questions
Helped
30313
Points
195
You might be trying to loading a 32 bit software packege to a 64 bit operating system. See it the store has a 64 bit version. Or you could upgrade the OS with the microsoft pro packege.
Thanks
2answers
I purchased windows 7 and I have print shop 22 how do I upgrade it to run with windows 7?
Check with Broderbund - either it will work OK - some programmes do or you may have to buy an upgrade - when have you heard that before!!
I installed printshop 2.0 deluxe on my new computer running windows 7 and I can't get the program to load up. What can I do?
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
1helpful
I want to install The Printshop Delluxe 22 on windows 7?
Hello
You can get help regarding installation of PS22 on windows 7 from this forum
http://forums.encoreusa.com/tm.asp?m=37934
hope it helps, if so do rate the solution
1helpful
I tried to install Printshop deluxe 22 on my new computer which has windows 7.it says that there is an error.what would you suggest
I suggest that you tell us EXACTLY what the error-message stated.
Or, start the Windows Program Compability Wizard, and tell Windows 7 that you want to install a Windows XP program.
Then, install the software.
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
2helpful
I use Windows 7 and the PrintShop Deluxe 22 will not work.
Microsoft's Windows 7 compatibility list shows this product as unknown at this time and recommends using the Vista compatible version. If you need to upgrade to the Vista compatible version there is a free update located at the link below.
http://na6.salesforce.com/_ui/selfservice/pkb/PublicKnowledgeSolution/d?orgId=00D80000000LhUC&id=50180000000AG17&retURL=%2Fsol%2Fpublic%2Fsolutionbrowser.jsp%3Fsearch%3Dprintshop%26cid%3D02n800000009un5%26orgId%3D00D80000000LhUC%26t%3D4&ps=1
2answers
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
