Question about M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card
MobilePre only sends out sound for one headphone
When I record using Sony Acid Pro, I can only get sound in the left headphone (channel 1..how do I get sound in both headphones ?
    New Friend:
Record on mono, not stereo..unless for playback
Posted on Jun 02, 2010
SOURCE:
Harman Kardon AVR 25II no sound from left channel
Sounds like the left channel has blown in your AVR 25II. If it was a faulty headphone jack it simply wouldn't send an output signal to the speakers.
Oct 01, 2018 | Harman Kardon Audio Players & Recorders
I can't hear the instrumental track when trying to record vocals on acid pro 6. What am I doing wrong?
you need to switch the monitor when playback on in the audio properties.
& use headphones to stop any feedback.
Sep 10, 2011 | Sony Acid Pro 6 Professional Music...
I have my Onyx Blackjack plugged into my computer but the sound is only playing and recording through the left channel, with or without headphones. Is there anyway I can fix this?
You haven't told us where the "sound" is coming from... If you are ONLY plugged in one channel that is all that will be recorded. We can't guess at how you are setup. Please provide an adequate description. If you only have a mono signal to start with, then get a WYE connector and jumper to the second channel.
Sep 05, 2011 | Mackie Onyx Blackjack 2x2 Recording...
While the Mackie Onyx 1220i unit is plugged into my computer I can port the sound through to my headphones via the headphone jack on the console. When I listen to sound play for about 2 minutes I'll...
OK... first thing is to DUMP ALL anti-virus and Anti_spyware and real time defragging programs as these resource hogs **** processing away from teh sound generation. Also is you are recording at the same time, if your disk is fragmented requiring a lot of head movement to record the time lags can cause buffer underruns and break up of audio... and eventually having the audio program "crashing" due to lack of throughput.
When doing audio work suspend all the resource hogs like the above mentioned programs. It is a good idea when recording CD's as well.
Feb 10, 2011 | Mackie Onyx 1220i Onyx1220i Onyx-1220-i...
M-audio fast track sound only coming out of right side
I havent played with acid a lot... but this is what i can tell you... most of the softwares have configurable inputs... seems like your inputs are configured as stereo input and hence it will pick up the signal from both the left and right discreetly... which means that you would need to feed audio to both the channels for the meter to pump on both bars...The other option is to PAN the track center and not hard left right... this would get audio to both ears of headphone as well as the output meters...
these are basically some of the few things tht will get u sound on both ears and bars...
The bigger question here thoug is why do you want to record in stereo?? and not mono?
Jun 29, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
Sony acid pro 6.0, microphone level when recording is way high
are u using the volume control or what mixer--u might want 2 try out the volume control--set it up recording
May 16, 2009 | Sony Acid Pro 6 Professional Music...
Can not record audio anymore
Does it create a track but there is nothing in it? Turn off your anti-virus software when you record, thats how I got mine to work. Kaspersky anti-virus was making it trip offline.
Apr 27, 2009 | Sony ACID Pro 5 for PC
Recording with sony acid 6.0
my vocals are off beat when i record why is that.
Mar 29, 2009 | Sony ACID Pro 5 for PC
Recording in Acid Pro 5
Are you plugging the instrument directly into the computer? If so you only have mono jacks from your bass, guitar so on and so forth! So in channel in only one to record! Try using a stereo microphone and record pointing at the amp. That way you will get stereo through your device. If that is not the problem make sure that the settings on the Prosonus is set to output stereo. And for most check all your plugs to make sure they are stereo inputs and outputs.
Sep 05, 2006 | Sony ACID Pro 5 for PC
Open Questions:
See all M-Audio Mobilepre USB Bus-Powered Preamp and Audio Questions
M-Audio Mobilepre USB Bus-Powered Preamp and Audio Interface Sound Card Logo
482 people viewed this question
Top M-Audio Computers & Internet Experts
Thomas F. Schneider
John Bolton
bigdaddyd2
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
