JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
Posted on Feb 20, 2010
JVC HD-52Z575 red screen
JVC HD-52Z575, when it comes on it's fine for a short period of time. Then the image flickers. The main image stays intact, but a second red 'ghost' image appears slightly to the right of the main image. Then slowly the entire picture begins to turn red until the screen is washed out in red.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 06, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
342
Points
The solution is an easy fix. Ignore anyone telling you to take it to a service center or to replace the convergence driver. You need to access the service menu on your television by using your remote control:
DRIVE CONVERGENCE Adjustment (Using remote control)
•Use the inner RGB box pattern.
(1)Set the [SLEEP TIMER] key to 0 min.
(2)Press the [DISPLAY] key and the [VIDEO STATUS]key simultaneously.
(3)Press the [9] key to display the RGB box pattern.
(4)Select the R mode by pressing the [DISPLAY] key.
(5)Adjust the R mode to setting as same as G mode bypressing the [CH ]+ / [CH -] key.
(6)Select the B mode pressing by the [DISPLAY] key.
(7)Adjust the B mode to setting as same as G mode bypressing the [VOL] - / [VOL +] key.
(8)Check to see that the cross pattern is white. If thecross pattern is not white, readjust (5) to (6).
That's it, your color is now corrected. Yes, I know...your welcome.
5 Related Answers
Anonymous
  • 59 Answers
  • Posted on Oct 23, 2007
SOURCE: convergence problem
sounds like convergence amps bad
A
Anonymous
  • Posted on May 11, 2008
SOURCE: JVC HD-52Z575
You both need to have a service center come out and reset the TV using the reset jig. This will correct the reverse image problem.
NJ Logan
Pat Adams
  • 31 Answers
  • Posted on Aug 27, 2009
SOURCE: JVC HD-52Z575 projection TV
sounds like a covergence problem, cost 350 to 450
Paul
  • 381 Answers
  • Posted on Dec 15, 2009
SOURCE: Hi i have a JVC HD-ILA HD-52z575 50
Replace light engine.
jomabug76
Josh Whitehead
  • 1148 Answers
  • Posted on Nov 03, 2010
SOURCE: jvc hd-61g787 Screen takes between
check jvc website support
JVC HD-52Z575 tv shows only a grey picture screen. I was watching a channel and tried to change channels and new channel won't come up, only grey screen.
JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV
www.amazon.com/JVC-HD-52Z575-HD...HDTV.../B...
Amazon.com, Inc.JVC HD-52Z575 52" HD-ILA HDTV-ready rear-projection TV ... The picture was artifacted and the color was good, but not great. ... From 5' some minor issues could be seen and the MPEG2 format did show its limitations, but at 10', it was a truly great experience! ... There is no true gray temperature, only high and low.
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will showyou step by step how to easily fix your big ...Missing: grey
JVC HD-52Z575 HD-ready rear-projection D-ILA monitor ...
HOW DO YOU RESET THE LAMP USE TIME ON THE JVC HD 56 G787 REAR PROJECTION
u need the real remote rm-18g hit menu till u get to lamp reset hit enter a screen will come up that says press ok to reset lamp timmer hit ok button than another screen will come up that says the lamp timmer was reset successfully
How do you reset the the lamp use time, after bulb replacement, on a JVC HD-52Z575 52inch Rear Projection HDTV
andycjavier,
See my tip at
http://www.fixya.com/TipsAndTricks/thanks.aspx?thid=8580883
Thanks for using FixYa and for the great rating.\
hardrocko
MY JVC52Z575 (D-ILA) HAS A REVERSED BLUE IMAGE OF ANY YELLOW IMAGE
I have the same blue shadow with reverse image on my JVC HD-52Z575 Did you see what the problem on yours finally was?
I need to replace the bulb and ballast in my jvc HD-52Z575 52 in rear projection hdtv-ready televvision. i need to know the part numbers and need to know where they are! I have no manual and would like to...
The parts diagram for the JVC HD-52Z575 is available here: https://www.searspartsdirect.com/model-number/HD-52Z575/1758/0333200.html . The lamp is part TS-CL110UAA. I don't see a separate ballast. If you look at the parts list for the cabinet, a Service manual is available.
I hope this helps.
Jvc 52 rear orijection top has doulbe image in
Ur convergence is dead.Must know how to solders?Must replaced 2 convergence ICS and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence to repair it ur self.The shop will cost u $300 for parts and labors.
JVC HD-52Z575
JVC HD-ILA PROJECTION T.V. #HD-52Z575
You both will need to have a service center come out to try to reset the TV using the reset jig. A JVC authorized service center will be the only ones that will have access to and training to use this jig. It is a good chance reseting it fix the color problem but it could also be something more serious.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
