Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The battery in my canon elph sd780 doesn't last long
The battery in my canon elph sd780 doesn't seem to last very long. It's only a few months old and lasted a long time at first but now only takes a few pictures then I get the "replace battery pack" message when I turn it on. Then I charge it and it's good for a few more pictures but very unreliable.
Anonymous
Level 3:
  • Master 691 Answers
  • Posted on Feb 21, 2010
Anonymous
Master
Level 3:
Answers
691
Questions
0
Helped
156562
Points
1852
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
tip
How to Recover Lost Photos and Video from Canon PowerShot SD780 IS
<span> <span><img src="maggiena_8.jpg" /><br /></b></span>Canon PowerShot SD780 IS</b> may be the slimmest Digital ELPH Canon has ever created with dimensions 2.10" h x .70" w x 3.40" l, .26 pounds and 2.5 display size. It captivates the senses with bold saturated colors and a daringly original design that matches the intensity of Canon's most innovative camera technology.</span> <span><br /></span> <span><span> <p>Owning to its wonderful picture quality as well as high resolution, it becomes the first choice for many photographer lovers. One more reason that it turns out to be so popular is it supports various standard storage media like SD/SDHC, Multimedia Card, MMC Plus and HC MMC Plus memory cards</b>. images, Video and other multimedia file like songs can be saved there. Usually, keeping a backup of data like pictures and other multimedia files is recommended at the very beginning in case the data was lost by mistake in the process of using the camera. However, if you forgot to backup, you have to use a third party program to <a href="http://www.card-data-recovery.com/">retrieve Canon PowerShot SD780 IS data</a>.<br /> <p><br />Cases about losing data</b><br /> <ul> <li>1. When connect Canon PowerShot SD780 IS to your computer and being transferring vocation photos from SD card to computer, accidently your camera shut down due to low battery. After change the battery and restart camera again, you may encounter the error message "memory card error" that means the memory card is inaccessible.</li> <li>2. While reading data or writing data to SDHC card, "I/O device error" occurs and all photos and video miss.</li> <li>3. On the process of shot, message "memory card is full" pops up to you. However, after deleting some pictures, it shows the same result.</li> <li>4. Connect your SD card reader to computer, the window pops up with message "you have to format SD card before using it". After formatting SD card, all your pictures and video lose.</li></ul> <p>Resolution</b><br />If the above phenomena happen, don't panic, lost photos and video in Canon PowerShot SD780 IS are recoverable. First thing to do is stop using camera to shot for fear that the data was overwritten. For the first two cases, make sure the SDHC memory card is properly inserted. If it still can't be recognized, try to use a card reader to connect it to PC. Or else you have to format memory card and use effective photo recovery software to get back lost photos. For the last two cases, you should rely on <a href="http://www.card-data-recovery.com/">Canon PowerShot SD780 IS picture recovery</a> program. There are many effective Canon digital camera photo recovery program available in the internet, just choose the perfect one for your camera. <br /></b><br /><br /></span></span>
on Jul 20, 2011 • Cameras
When I turn on the Canon SD780, it says the card is locked. Have tried about 10 cards and it says "card locked" on all of them. Purchased a new card and I get the same message. Cannot reformat...
This seems to be a particular issue with this model camera, noted by the archived Fixya problems listing for this model. Noting that the slide switch doesn't seem to correct this problem (resulting in 4 thumbs up) for the majority, the only other possibility is that the corresponding switch internal to the camera might be gummed up. As such, please see the "toothpick fix" (Fix #4) of this link.
Lens making strange clicking noise when turned on or zoomed in.
If the noise wasn't there for 3 days and is there now, it can only get worse. I would return it for a replacement.
Flash will not fire on Canon SD780 IS Elph
The flash circuit is defective. As it's only a couple weeks old, recommend just exchanging it for another from your place of purchase. You shouldn't be attempting repair while its under warranty.
My Canon Power Shot SD 630 Digital Elph
When was the last time that you replaced your rechargeable battery? It was only meant to last a couple years, regardless of the amount of its use. If the battery is old, a generic replacement is relatively inexpensive these days. Look for those rated 4 or 5 stars:
http://www.amazon.com/s/qid=1241307462/ref=sr_st?keywords=nb-4l+battery+-charger&rs=172282&page=1&bbn=172282&rh=n%3A172282%2Cn%3A%21493964%2Ck%3Anb-4l+battery+-charger&sort=price
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
