Have duet dryer model #9200Lw1 it runs and dries clothes slowly, have to run it 2 times to dry clothes. Cleaned lint trap and disassembled down to motor, have pretty good flow to outside of the house even though its 20 feet or so. Could it be the heat element, or what else do you think, thanks
SOURCE: Whirlpool Duet Dryer - Working but no heat
MAKE SURE YOUR VENT ISNT CLOGGED AND YOU HAVE 220 VOLTS AT THE DRYER IF ALL THIS CHECKS OUT GO TO ELEMENT WHICH IS BEHIND THE LOWER PANEL IN THE FRONT.REMOVE THE PANEL WITH THREE SCREWS ON THE BOTTOM AND TAP DOWN AND OUT AT THE SAME TIME. USE A VOLT OHM METER AND CHECK OHMS ACROSS THE TERMINALS OF THE HEATER IT SHOULD HAVE A OHM READING IF NOT CHANGE HEATER AND OPERATING THERMOSTAT GOOD LUCK
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.
SOURCE: whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
SOURCE: clothes not getting dry
Heating element only stays hot for 30 seconds after starting dryer. Takes 2 hours to dry clothes.
