Our action replay has turned to a white screen someone told us to hold A+B+Start+Select to get it to work again we just need to know how to get it from the white screen so we can plug it into the computer and run upgrades on it if that A+B+START+SELECT thing works how long do we need to hold them before it will work
SOURCE: Broken action replay
try this:
1.) Turn on the DS holding the (A) + (B) button.
2.) Then
press and hold [Start] + [Select] While still holding (A) + (B) after
the Nintendo Screen Is Displayed and Before it says "This Product Is
Not Endorsed by Nintendo"
note: this resets your AR so u will loose all your codes
SOURCE: Not enough free space on action replay. can't load cheats.
You corrupted the data on the AR when you turned off the DS while it
was trying to write. Now you have to reset the AR. To do that, make
sure the AR is connected and the DS is turned off. Hold down A+B and
keep holding them down while you turn on the DS. Just before the
message that this product is not endorsed by Nintendo, and while still
holding down A+B, hold down Start+Select. Keep holding all these down
until the Enter Game Card screen comes up. It's tricky to keep all the
buttons held down, so you might have to try it a few times before it's
really reset. You'll know if it's reset because you'll be able to copy
a code over to your AR.
Then you go back to your disk, and update your information it all comes back. took me a while to do this.
SOURCE: Action Replay DS trubleshotting
unistall the CD, then install it again. open the action replay manager. then, plug your action replay to the computer. a screen will pop up. the first one ask whether you want the message to be dusplayed or not. press yes, and install. while installing, there should be an error. it says stick in the disc, or try other options. try the disk one and press next. if it dosent work, repeat steps above and select other options. browse the CD file (my computer, then the CD) and it should reboot and work. worked on my brothers :D good luck :D contact [email protected] if you need anymore help :D
SOURCE: ttds card and action replay
You can't put an action replay with a TTDS in the same slot. The action replay cannot read all of the games the TTDS has.
SOURCE: My Action Replay DSi starts up with white screen.
i saw a vid that shows you how you MIGHT be able to fix this heres the link: http://www.youtube.com/watch?v=l7jshKuBcaI
