Jackson 25 in. TempStar HH Free-standing Dishwasher Logo
Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does this machine require a booster heater? If so,
Does this machine require a booster heater? If so, can it be electric?
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Feb 20, 2010
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2050984
Points
24677
Maybe and probably. Speak with your Jackson distributor about this. He probably has a solution for you that is compatable with your equipment.
Thanks for your interest in FixYa.com
Hobart LX 30 undercounter dishwasher, commercial Does this model require booster?
Most of the Hobart LX series of dishwashers have their own built-in booster heaters. To check for one, remove the lower front panel (2 screws). The booster heater, if present, will be a stainless steel tank on the left side. If it doesn't have a built in booster heater then it was meant to be used with chemical sanitizer instead.
Booster heater is leaking from the bottom'. I don't know the the make or the model.
Hi you may have taken care of this by now, but anytime they start leaking from the bottom, they have rusted out and you will need to have it replaced.
Shastalaker7
1helpful
Does my Bosch SHU3032UC have a heat booster?
The dishwasher has a built in instantaneous water heater, so even if the water feeding the d/w is cold the machine will heat it the the temp required for the cycle you have choosen. Reducing the temp will not effect the wash quality at all, in fact having a lower temp or cold water filling the machine will make the drying cycle at the end of the program more effective.
Hope this helps, please leave feedback.
Leaking drain, I think?
hatco booster heater leak at pop off valve
With the hatco booster water for automatic dish machine
Under normal and regular operation Hatco recommends that the unit be turned on at all times.
If the booster heater will not be used for an extended period of time or will be exposed to freezing conditions it should be drained to prevent damage to the unit.
1helpful
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 • Dishwashers
Hobart LX 18 needs compatable booster heater
A hatco C9 or C12 would be plenty big enough.I would use the larger kw unit if incoming water is very low,but it needs to be 140 degrees coming in so it doesnt sometimes trip the hi limit.
1helpful
4answers
Hobart LX30
Hopefully you took the suggestion to run the correct 50 amp 208-240 service to the unit.
Converting the unit to an LX30C has a couple of pitfalls. The LX30C is connected directly to the incoming water supply, which should run 120-140 degrees. By reprogramming the unit as an LX30C, the booster would be disabled, which would mean the incoming water would flow through the de-energized booster and be cooling off while it sits in there between cycles and when the unit is shut down.
The incoming fill plumbing (5/8" heater hose) would have to reconnected from the fill solenoid valve directly to the vacuum breaker on the rear of the unit to bypass the booster heater.
On the 208-240 volt LX18/30/40's, the pump motor, booster heater, and sump heater run on 208-240. To convert it to 120 volts you would have to replace the sump heater and reconfigure the motor wiring in the motor junction box.
By the time this is all done, you've downgraded a great machine, confused the next service guy, and have to deal with nasty chlorine and all of it's headaches.
I
Booster heater quits heating water after a few minutes of use and you must hit reset button to get it to work again. What would be causing this? For Hatco C36208 Booster Heater 3 phase
#1 I would check that you actually have 3 phases connected. #2 I would also check the ground. There could be a loose ground, or depending on the installation, the ground could be defeated by rubber washers in flex lines. Fix this by running a wire from the casing of the water heater to the pipe, bypassing the flex lines.
#3 Replace the thermastat. The thermastat has the reset button on it.
#'s 1 & 2 are very minimal in cost. #3 is still affordable.
Please rate this solution
Repair
Here's a list of repair services for water heaters around Chicago:
http://local.yahoo.com/IL/Chicago/Home+Garden/Construction,+Repair,+Improvement/Water+Heater+Services
Top Jackson Dishwashers Experts
ADMIN Andrew
ADMIN Andrew
Bonded Repair
Don A
Don A
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
