Hi I need a new swing arm for a SL 1210 do you know where I can get one and how much it would cost?
many thanks
Look here for a new tonearm £52.99
http://stores.ebay.co.uk/methleykev
hi fletch83.
this could be the tone arm bearings too tight,damaged or in need of a little oil.
i had a similar problem on my 1210, it kept jumping all the time,ruining my mixes! it turned out it was the bearings too tight.
unscrew the counter weight so that the arm hovers over the platter and move it to the centre with anti-skate on zero.
slowly turn the anti-skate round to three and the arm should move over to the arm rest smoothly,if it stops before the arm rest or isnt smooth theres your problem,loosen the bearing adjuster slightly and try the hover routine again until its as smooth as you can get it. it is possible,if the turntable has been transported without dust covers the bearings or the pin could be slightly damaged from knocks on the top of the tone arm assembly.
let me know how you get on or if you need any more help.
darren
