Can't connect to internet, icon shows as internet connected But can not get on line, either wired or wireless.
Trendnet 652BRP wireless router. I have spent 8 hours trying to get it working. I reset the router to factory; nada, I used the wizard; nada, I tried to manually configure; nada. I give up back to my old wired router , until I can get some help. Router is under warranty, but customer support is awful. Help!
are you using pc of phone
on pc there will be a tool bar (line of icons) at the bottom of the screen one will be E in a circle that is the explorer browser that will connect to the internet.
Hi
When you tap the icon for the store, are you on line, either via mobile broadband or a WiFi network that is connected to the Internet?
If you cannot surf the internet or connect to you email, you will not be ale to go to the store either, and the fact that the loading screen stays running for a long time, is a strong indicator to me that you are not connected to the Internet.
Cheers
It's a semi-long process. Do you have a wireless router hooked up to your computer? If so just go to settings then network settings in your ps3 menu. If you have the wireless router then put wireless connection and its straight forward from there. If it is a wired connection and hooked to your ps3 than put wired connection and again its straight forward from there.
When you look at the Manage Network Connections link on the Network and Sharing Center you do not see Local Area Connection? Do you see Wireless Network connection? You need to check the device manager to see if the card has been disabled.
It should show two entries with no red or yellow marks. One for wireless (WLAN) and one for wired (Ethernet)
right click your my network places icon from the desktop. Select L ocal area network. Right click on that and select properties. Select Internet protocol TCP/IP. At the bottom you can find show notification icon when connected. click on the check box.
Firstly connect to your router by typing 192.168.0.1 in the internet address bar (sometimes 192.168.1.1) and this should connect to your router. Now log into the router i dont know what router you have but mostly its admin and admin or password = password. Make sure all the settings there are correct like your ISP login name and password. Hope this helps
Solid Blue Wireless computer is connected to the Router
Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
OFF Wired computer is not present
Solid Blue Wired computer is connected to the Router
Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
OFF Router is off
Blinking Blue Router is booting up
Solid Blue Router is on and ready
E. Modem Status
This icon lights in blue to indicate that your modem is connected properly to the Router.
It turns amber when problem is detected.
OFF Router is NOT connected to modem
Solid Blue Router is connected to modem and functioning properly
Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
Internet. When the light is off, the Router is NOT connected to the Internet.
When the light is blinking amber, the Router is attempting to connect to the Internet.
When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
OFF Router is NOT connected to the Internet
Blinking Amber Router is attempting to connect to the Internet
i) on the bottom-right-coner of computer desktop(system tray) you will computer like(double)icon showing the connectivity to internet, see whether it is showing a red corss(X) symbol on it if it is so then there is no internet connectivity, other wise you will see a movement or graphic on the icon, if it is so then there is internet connectivity.
ii) if there is red corss(X) symbol on it try remove the internet connection(wire) and replace it and if you use an internet service provider which require id, password try to enter them after installing sofware provided by internet service provider.
iii) otherwise contact ur internet service provide to make sure internet connection is working perfectly from his side.... and he would assist in better what would be the problem....
iv) try to change you browser, switch some other browser like opera, firefox, .......not Internet Explorer....
