(Caution ) sway bar end is under pressure.
1.go to AutoZone get new linkage bars or just the bushings depends on wether the bar has grooves wore into them from use and new nuts. 2. Raise and safely support vehicle,3. remove tire, 4.using floor jack safely support the lower suspension arm and raise to remove pressure on the linkage bar between swaybar end and lower arm 5. remove the nut under the lower suspension arm that retains the swaybar linkage ,6. loosen and remove nut at swaybar end. 7.at this time only lower the lower suspension arm enough to remove the linkage bar. install new bushings or bar to the swaybar end don't completely tighten nut at this time.8. install new lower bushing then jack the lower suspension arm back up aligning the lower end of the linkage with the hole in the arm once pressure is lifting the swaybar install the lower nut and tighten at this time Torque top nut to35-47 Ft lb and bottom nut 8-10- Ft lb lower the jack from under the lower arm and install tire lower vehicle ready to go Appx 1 Hr per side
need to replace complete rear sway bar end linkage on both sides , should i follow the same instructions ?
