I have been installin game in samsung star S5233 wit tkfile explorer but the prble is that when i drag file from pc to mobile the error comes "(tk file explorer MFC application encounter a problem)" now what to do plzz help
Jar file be easily open in a computer, but if you trying to open a .jar file in your Samsung phone, then you cannot open it directly. A jad creator is needed which you can download in the internet. It also required tk file explorer. You have to download this two from internet. After downloading you'll require a pc suite software of your mobile phone. Install a pc suite software of your mobile in your computer. after installation you have to connect your mobile phone to pc via data cable wire which came with your mobile phone. After connecting it open the TK file explorer which you have downloaded from the internet and follow the instruction for installation.
You can use tk file explorer to update the contents in the game folder.......just connect s5233 to PC. First time you should be prompted with a 'device installed and ready' message.
Execute TkFileExplorer_2.2.exe
Go to Settings - COM.
Scroll down Port window: You should get just one COMxx option. Choose it and press OK.
Go to File - Connect. You should get the F480 File System Tree at TkFileExplorer bottom half side.
Go to /Exe/Java/Games
Create a New Folder for your game
At TkFileExplorer PC upper side select game JAD/JAR files and copy to s5233 created folder using drag&drop or right button menu Download option.
Repeat steps 9 & 10 for all games you want to install at a time.
If we need to unlock the games,we need unlock codes.I do not have the unlock codes.But instead,
We can delete that games using file explorer and reinstall the full version of that games.If u need I can provide you many games.Applications can also be installed with games using file explorer. s3310 supports .jar file when installed with .jad file,If not,it says "not supported" error.
Connect ur phone with pc via USB start the samsung pc suit software and then close it. Next right click MY COMPUTER and go to device manager VIA hardware.Click to the modem option and then click the Samsung modem then select the advanced option and then advanced port settings. U'LL FIND THE COM PORT NO. ENTER THE SAME IN TK FILE COM PORT OPTION AND THEN CONNECT.
Detailed Guide on installing Games and Apps for S5233/S5230
(Note: Tried it myself many time. Works perfectly).
I am assuming you have the game you want to install with you. In this
example I downloaded Erix.jar game. And created jad file using JADMaker
(Google for JadMaker, to download it). Using JADMaker you need to
create ".jad" file. Now I have "Erix.jad" and "Erix.jar" files.
Connect the phone to PC and start "Samsung New PC Studio"
Open the File browser and go to "External Memory". Create a directory there (Name it anything you want your game name to be).
I will be creating a directory called "Erix". Then copy the Erix.jar
and Erix.jad files into that folder. Disconnect the phone from PC now.
Got to Menu -> Browse -> Enter URL
Type -> "http://m.GetJar.com"
Browse down and you will see "Quick Download". Click it. Then enter
quick download code as 51799 . Download and install it. Exit from
browse.
Go to Menu -> Applications -> Games and more -> LiteFTP
You will be in LiteFTP menu
Select Mmc (Memory card) and click OK. It will be at end.
You should be able to see the folders in memory card. Select Erix
folder (dont enter it) and press "123" button. Then press "1" (This
will copy the Erix folder). Select "Back". You should be back in "root"
directory.
In root directory you will see a folder with "dont enter" symbol named
"My PrivateMy PhotoMy Video .......". Select it and press OK to enter
it.
There will be nothing in the folder. Now paste the Erix folder. To do so press "3" to paste.
Exit the LiteFTP.
Open "Keypad" and type "*#6984125*#" (Without quotes)
This will automatically open "Admin setting"
Select "4 Internals" and enter "*#9072641*#" (without quotes). And confirm.
This will take you to "Internals" menu. Select "6 Storage settings".
Select "2 Update media database"
then select "3 Update Java DB"
then select "10 Create Ax Dat File"
Exit from all those menus.
Now go to Menu -> Applications -> "Games and more" You should be
able to see new icon "LiteFTP/files/Erix". Rename it if you want to.
Then start the game.
All Games and Software's installed in this way will be located in Menu -> Applications -> "Games and more"
you directly connect your phone without pc suit go in phone settings and enable....mass storage connection.............if stilll derz a problem u re- install the drivers there is game solution go to http://www.softpedia.com/progDownload/JADMaker-Download-8344.html these website and download jad maker after downloading open and extract zip file and click on jad maker and drag your mobile jar files jad maker will create two files that is jar and jad and extract both files in your mobile others folder.........
The previous one was good.....but instead you can use tk file explorer to update the contents in the game folder.Just connect s5233 to PC. First time you should be prompted with a 'device installed and ready' message. Execute TkFileExplorer_2.2.exe
Scroll down Port window:You should get just one COMxx option. Choose it and press OK. Go to File - Connect. You should get the F480 File System Tree at TkFileExplorer bottom half side.
Disconnect USB cable Dial *#6984125*#
Go to Internals (Master Key: *#9072641*#)
Go to Storage Settings and select Update Java DB
In the previous one you needed gprs, in this one you do not...And remember to download " .jad file " for you game/app (You can fine tons of free games/apps form GetJar ) If i was helpful, kindly do Rate!
