Hi, i have an original sony psp and i have firmware 3.90. i have downloaded some themes from the official website on my pc, connected my psp via cable and there is no theme folder... i've tried dropping the themes into all of the other possibilities and also tried creating a themes folder but none of my solutions have worked... any help VERY appreciated, thanks
Thanks for trying mate but its still not working... maybe its a problem with the actual files... know any sites i can use to find themes???Thanks for trying mate but its still not working... maybe its a problem with the actual files... know any sites i can use to find themes???
klaxxonsux, step 2 of your suggestion doesn't do anything on my psp so i obviously can't use the rest...klaxxonsux, step 2 of your suggestion doesn't do anything on my psp so i obviously can't use the rest...
You can't post conmments that contain an email address.
First of all you need a PSP running the Firmware 3.40 OE 1: Turn off PSP (hold off buttoon for 5-10 sec) 2: Turn back on while holding the R button 3: You have now entered the Recovery menu, go to advanced > Toggle USB (flash0) 4: NOW VERY IMPORTANT MAKE A COMPLETE BACKUP OF FLASH 0!! 5: Save the backup of the FLASH 0 somewhere on your computer (DON'T DELETE IT) 6: Now swap the files found in the Theme folders with files existing in X:VSH\Resources\ and x:\Font\ (.RCO go in Resources, ltn0.pgf goes in FONT) 7: Press Back on the PSP recovery menu 8: Press Exit on the PSP recovery menu 9: If your PSP boots with a error, first try to go to theme menu: change to another color (if this don't work: read thetroubleshootingg below. then return to step 1 if nothing work). if it don't boot at all. Return to Step 1 and do over again with the backup of Flash0
umm ok well i wanted to do the same thing and i called a file themes and it dident work so i put the pictures file and it worked of but it isent a theme its a wall paper.
or even you can sointo settings and there might be a theme file
hope it helps
p.s can u plz rate me well i wanna become a wiz
thanksumm ok well i wanted to do the same thing and i called a file themes and it dident work so i put the pictures file and it worked of but it isent a theme its a wall paper.
hope it helps
thanks
In 2005 Sony released the PlayStation Portable (PSP) hand-held system in the United States. The system allows users to play games, listen to music, view pictures and watch movies on the go. In 2007, Sony released an updated "Slim" version of the PSP that has the same features but is significantly smaller than the original version. One of the most popular features on the PSP is the ability to personalize the device with different themes that give the PSP a customized look. Luckily for PSP Slim owners, installing a theme to customize their PSP is a simple process, only requiring a few steps. Please just follow the steps below: 1. Insert your Memory Stick Pro Duo into the memory stick slot on the side of your PSP. Turn the PSP system on.2. Plug your PSP into one of the USB ports on your computer with the PSP USB connection cable. 3. Navigate to the "Settings" section of your PSP's Cross Media Bar. Select "USB Mode" from the list of options to place your PSP into USB mode.4. Double-click on your PSP in the "My Computer" section of your computer to open the PSP's root directory. Open the folder titled "PSP."5. Create a folder inside the "PSP" folder and name it "THEME." Be sure to use all capital letters.6. Open the Web browser on your computer and navigate to a website that offers PSP themes for download. PSP-Themes and PSP Theme Central are two websites that provide this service. Locate a theme that you like and click the download link to begin the downloading process. Allow several seconds for this process to finish.7. Unzip the files you downloaded in Step 6 using an expander program like WinZip or WinRar. Locate the file with a .ptf extension. For example, psptheme.ptf.8. Drag the .ptf into the "THEME" folder you created in Step 5. Right-click on the PSP icon on your computer and select the "Eject" option to eject your PSP from your computer.9. Navigate to the "Settings" section of your PSP's Cross Media Bar. Scroll down and select the "Themes" option. Select your theme from the menu that appears to set that theme on your PSP. I hope you find it very helpful.Thank you for choosing fixya
go to a website that caters psp themes, you can google it if you want, then download the themes, save it on your mem stick, make sure that you copied it on the correct folder, you will see a theme folder. disconnect you psp, then go to settings on your psp then theme settings, there you will see your installed theme.
hardboot your psp and hold r then you should see recovery menu go to plugins and turn cxmb.prx off okay and then delete the theme from your mem stick and then reenable cxmb.prx
Hi, first of all you DO NOT need custom firmware to install themes onto your psp, you need a firmware 3.71 or later to do it. First of all go to a theme site E.G http://www.psp-themes.net/select a theme you want and download it to your computer. then connect your psp to your pc. open the psp files, go PSP, then there should be a folder called THEME. copy the theme you downloaded and viola. this is the folders in psp memory stick:
the theme file must be .ptf
Hope this helps.
once connected by usb you have to go onto the psp root and should find a folder called THEME place the file into there but older firmware versions do not support themes after placed the themes in the folder disconnect the psp and on the settings menu of the psp go on display - themes and select the theme there
