Akai LCT2016 20 in. LCD Television Logo
Posted on Feb 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AKAI LCT2016 20" LCD TV- Dosn't Resize picture properly
SO one day, i went to turn on my TV, couldn't find the remote, and pushed the button on the side of the tv. it shocked me, then turned blue and then turned off. when i found the remote and turned it back on, i found that the pictures for Composite(Yellow cord), S-Video, and VGA all had failed to correctly auto resize themselves. instead, part of the picture had been moved off the side of the screen. for VGA, only half the picture shows up. the TV(Cable in) and Component(YR/CR/PB or something like that) worked fine. im unsure of what caused the problem, and even less sure on how to fix the problem.
Chi Chu
Level 3:
  • Akai Master 8,457 Answers
  • Posted on Feb 20, 2010
Chi Chu
Akai Master
Level 3:
Answers
8457
Questions
0
Helped
2822811
Points
26282
U can't fix this problems.Omly replaced board.The Tuner main board have dead componnents.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner signal board for replacement.
I hav ethe akai model number pdp4295ed and the color is very bad on the screen. how can i adjust it? it was a power outage one day and the tv came back on this way.
U have the tv original remote wright?Yes?Push the tv remote button that said Menu.Go into the tv Menu at already or goto PICTURE than go down to do a resetting than everything will return itself back to the factory setting and now just go to the Colors Setting lower -30 less than the colors on the tv now ur tv should be good and have a correct pictures coloring.
My wife thought it was hooked to a cable box for high number channels and pushed 707 on the remote TV sig went out. TV powers up but no menu no signal just a power light and the background is on but no...
Hello
have you tried pushing 003 on the remote or the AV buttons?
All I can think of is that you must the get tv BACK ON the right channel or AV Input.
Hope you have a better day
Akai ct-2202 tv turns on but no picture when i connect cable tv wire, cable oprator said me your akai tv tuner problum Please solve my problum Sanjeev Kumar Delhi, India
sir . i need akai ct2202 remote control model no. i lost my remote in transit and without it i'm not able to use the tv. my mail id : [email protected] pls help. thanks & regard's. V.SRIKUMAR
3helpful
I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
2helpful
My Akai LCD TV/Dvd player will not turn on
http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Akai TV troubleshooting
Click here to find the power box for your TV. I would suggest to contact them first with the proper model of your power box before buying it.
TV will not come on by using the remote control
I think I have an answer. This comes from someone from the Geek Squad. She said that somehow the TV was turned off at the TV and not the remote and that has reset the system . Try pushing the "STAND BY' button and everything should work as normal. I will find out for myself in the morning. Good luck to us both !
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Akai PT5598HDX/SMS won't turn on
Just a thaught, I could be wrong, maybe a problem with the power button on the remote ? It might shut the TV off, and when you do keep pressing the remote button, the red light on the TV will keep flashing like that also. Ive seen this prob on a few other blogs, so seems to be pretty common. I know I like to keep the remote pointed at the TV all the time, maybe try pointing it away for a while, just to see.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
