Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
Anonymous Posted on Feb 20, 2010
Sony trinitron xbr screen periodically goes black. The audio stays on but the video cuts out.
Anonymous
Level 3:
President:
  • Master 2,992 Answers
  • Posted on Feb 20, 2010
Anonymous
Master
Level 3:
President:
Answers
2992
Questions
Helped
1093615
Points
9665
Sony sets have several protective circuits that blank the screen if something happens that might damage the picture tube. One of the more common causes is trouble in the vertical output circuit. Given the age of your TV (the XBR models have been around a while), this might also be a symptom of a picture tube starting to fail. Most of these sets have circuitry (called AKB) that adjusts the color drive signals to the picture tube to keep them balanced. If one of the colors is enough out of range the screen will blank. It might be the tube itself, or failure of some part in that AKB circuit. The set might also have defective parts in the input switching or video processing stages.
Unfortunately, I can't suggest any place you might look if you want to try repairing this on your own. This kind of trouble usually needs to be diagnosed and repaired by a professional TV technician who has the service information to track it down.
Hope this has been helpful. Thanks for using Fixya!
Testimonial: "It sounds like you know what you are talking about."
Sony Bravia XBR-65X850C. How can I repair it?
It is a good set and worth repairing. This is explains the problems of home repair.
https://www.fixya.com/support/r29790007-repairing_own_television
We do have a television expert named Larry. He may be along soon.
Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
My sony trinitron xbr tv turns on stays on a few seconds then powers off by its self and it gives 5 red blinks from stand-by
This is according to the sony service manual
Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Sounds like a failure in the C Board or AKB Circuit.
Best to take it in to a service center.
Hi my name is jeremy snow and i have recently had problems with my sony trinitron xbr 1997. lately the picture like scrunches up into the top of the screen and the tv just goes black and now like sometimes...
You have two problems. Dry joints causing the no picture and capacitors causing the frame cramping.
A 680uF 35Volt capacitor will fix the frame cramping and re soldering underneath almost everywhere will solve the intermittant picture fault.
7helpful
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Sony trinitron xbr 40'' tv turns off immediately after turned on using power button
thats not a good model number for sony they usually start with kv- but it looks like is protecting itself maybe its not regulating the power supply
No picture, Standby blinks then goes out
Sony Trinitron XBR
Problem/ Standby Flashes Power button
Sony 36 in.tv fdtrinitronwega xbr
This is a duplicate posting. I responded in the initial one. Please see that response.
Dan
Sony Trinitron XBR
VHF/UHF works for me. Make sure the game/tv/video rtc tab is correct
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
