You're good. I've always had my 19 Ultra II hooked to the battery, and it works beautifully. This way you'll always have an outstanding power and ground connection.
If you are crossing the 2 large connections that's the same as having the wire running straight from the battery to the starter. If it's not starting then you either have a bad battery, bad connections from the battery, or a bad ground connection,,, or a bad starter.
Open the two cart doors on the bottom front of the grill, if your DCS model has doors.
Remove the drip pan under the grill by sliding it forward.
Locate the 9-volt battery behind the grill control panel in the compartment directly below the "Ignition" button on the front of the panel. The battery is mounted vertically to the connection plate.
Pull the battery straight down to disconnect and remove, using pliers if necessary.
Hold the new battery in position below the connection terminals so that the positive (+) post on the battery is facing inward beneath the grill. The positive post is the larger of the two posts on the top of the battery. Push straight up to connect the battery.
Slide the drip pan back in place and close the grill cart doors.
If you can move the flywheel or main pulley by hand the engine is not frozen, so its starter, solenoid or battery or connections to the starter or battery. Usually dead battery or corrosion on the terminals. Jump the battery to test using known good cables. Sometimes going straight to the starter with the cables is a necessary test to bypass hidden connection rot. Having lights is not a good test of battery capability.
a 12V battery from car?? in cars battery are actually between 14V(fully charged) and 11V(empty) else i don't know but the best way to be sure is using a regulator (this for example)
Make sure it is not battery or motor, jump the battery + & - to the motor + & -, if it works it will be the control box
30 minute fix for very cheap
ITEMS NEEDED Get a Potter & Brumfield relay (5 poles) 2-3 feet of wire 4 female wire ends to plug into relay
HOW TO FIX Take apart razor so you can see the black control box
Unhook throttle plug, this is the one with 4 wires (2 brown & 2 orange on mine)
Wire relay: 85: Ground 30: Red wire from switch to control box, if you wire this straight to battery it will work with switch on or off (killing battery) 87: Red wire to motor 86: Brown wire from throttle plug
Run a wire from 12v (battery) to other brown wire on throttle plug
END RESULT When the throttle is activated, it closes the loop in the brown wires, triggers the relay, activates the motor
You WILL NOT have the throttle control, it is wide open or off when you activate/de-activate the throttle
This will save you $30 for a new control (brain) box.
Is this a straight 24V system... not a 12v - 24v.Correct..
The best advice is use a 50-60 amp resettable breaker..with 6 gauge wire (minimum 8 gauge) ... make sure your connections are clean, tight, and greased to prevent corrosion. USE a BIG HEAVY "jumper" cable between the + and - terminals.
Here are several sites that explain what you need to know..
I went from a 12-24v to a straight 36v Motorguide on my 21ft triton.. WOW!!!! talk about BAD A$$!!
I use the felt washers under all battery connections and the battery spray liberally on each connection.. 24 and 36 volt Wiring Diagrams
its because your yellow wire isnt connected straight to the battery it would probably be connected to switched connect it to the battery and it will fix the prob
either the battery is not good or the battery terminals are bad.
the ignition lights should come on , if they do when the charger is connected.
I assume you are connecting the charger or jump cables to the battery terminals
Be careful jumping of a bigger battery it can spike the regulator when the engine starts and tries to produce 50-60 amps
If the battery begins to smoke as soon as you start the player this means that there is a direct connection between the positive terminal of the battery and the chassis or body of the car. this causes a short circuit condition causing maximum current to flow thru the battery ( a very dangerous situation). Probably, if this is the first time you have turned on the player , it was not installed correctly. If it has been working okay for awhile and just started this ,then it is caused by a pinched power wire.Check the power wires from the player ( red, black, green.) the red wire should be connected to the fuse block of the car and it should have an inline fuse connected to the red wire.This wire should NOT go straight to the battery! The black wire should should be connected to the chassis of the car.The green wire can also be connected to the chassis of the car,drill a hole and drive a sheet metal screw in the hole and fasten the green wire under the screw and tighten.If the red power wire is run straight to the battery without an inline fuse and somehow gets pinched against the car chassis it will cause a short circuit, If the red wire is connected to the chassis or negative pole of the battery and the black wire is connected to the positive pole a short cicuit (smoking battery) will occur.
cool. Was there an issue?
And?
And? You need to post a question, what happened and what is your question?
