1996 GMC Sierra Logo
Anonymous Posted on Feb 19, 2010
I changed my blower fan control (in dash unit)new resistor and relay and still no go any tips
Kevin Rahme
Level 3:
  • Master 401 Answers
  • Posted on Feb 20, 2010
Kevin Rahme
Master
Level 3:
Answers
401
Questions
0
Helped
257063
Points
1394
Remove the heater control head
there is a square connector with 8 terminals but only uses 6 wires
the connector is black it will have YELLOW,LIGHT BLUE,ORANGE,BROWN wires and i can't remember the other colors
the BROWN wire is the main feed for the control head check for 12V
if you do not have 12V then there is a open between the connector and the fuse pannel
if you have 12V then make sure the plug is not melted and the terminal is good
hope this helps
1helpful
Where is blower fan relay located
Doesn't it work in any speed ? Could have Blower Motor Control Processor if yours has automatic HVAC .
Or if manual it has blower motor resistor . Both are located under passenger side dash . Remove insulator panel under the dash if it has one !
ORO How to replace blower motor resistor in Chevrolet Silverado
2005 Chevrolet Tahoe Blower Not Working
2answers
2012 jeep libery blower motor control processor location
Processor? This system consists of a control unit ( switch/selectors ) a blower motor resistor and a blower relay. If the blower fan is not working on all speeds, suspect a resistor ( common problem ). If the fan is inoperable, possible fan motor,fuse,relay,wiring and in some cases the resistor as well. The resistor is located under the passenger side dash area close to the heater motor. The wiring coming from the heater motor will plug into the resistor
1helpful
3answers
How do I change heater fan
It would help to know the make and model. Different manufacturers put them in different places and mount them different.
2answers
Fan blower not blowing
Most likely need a new blower motor resistor
2004 Chevy Trail Blazer,blower fan not working and the brake and ABS lights are on in the dash, checked all fuses,nothing blown. Can not seem to narrow down which relay goes to this section. Any thoug
Hello Linda! Replacing the HDM relay for the low beams will not trigger any of these problems. If the blower isn't working, you probably need to get a new blower motor resistor (for manual controls) or blower motor module (looks the same) for automatic climate control. To access, need to remove the plastic kick panel near your feet on passenger side. After removed, look up you'll see the resistor, it's about 4" long with 2 small screws in it. You'll also need to drop the glovebox door to remove the connector from the resistor to the motor. Suggestion- buy a pig tail for the resistor also, these tend to melt. Very common problem. The ABS dash could be a bad wheel hub assembly or a hub starting to go bad.
2answers
Heater / air conditioner fan control doesn't engage fan. Previously, it only worked in high speed.
I would replace the blower motor resistor first then see if that corrects this. The resistor is located next to the blower motor under the dash.
The location of the fanswitch relay on the blower unit
If your fan is not working, its almost certainly the blower motor resistor. Also called blower control switch. They go out a lot on Civic from the 90s. Its under the dash board on the passenger side near the blower motor.
A/c switch or relay on 2000 cherokee jeep My level on ac unit only works on number 4. Went to U Pull It got another unit and it only works on number. My next step is the relay plug but have no clue...
it sounds like the blower resistor/module is bad. It is located either behind the glove box or under the passenger side of the dash near the blower motor.
Manual climate control uses a blower resistor to control fan speed. it will have 5 wires going to it. A tan. lt green, lt blue, an 2 black with tan wires.
Automatic climate control will have three wires going to the blower motor module.
Heres a how to tip that may help explain what is going on
http://www.fixya.com/cars/r6571076-blower_motor_not_work
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
5helpful
2answers
BLOWER HEATER FAN SWITCH IS ONLY WORKING ON HIGH SPEED WITH LITTLE HEAT.
The blower motor fan is controlled by the blower motor resistor.Its the resistor which controls the fan on respective speed which you select.But if the resistor goes faulty,then it will not be able to set the required speed which you set for fan,so it works on high speed only. In this case you will have to replace the blower motor resistor. Check fog for the location of blower motor resistor location:--- see part number 8 in the diagram below. helpmech_11.gif
The blower motor resistor is located next to blower motor under the dash.Its fitted with 2 screws and a wiring connector.You have to remove the screws and wiring connector and take the resistor out and place the new resistor in same position and connect the connector as well as screws. ------------------- this should help.Thanks.Helpmech.
8helpful
3answers
2004 Chevrolet Silverado Heater/AC Blower on without Ignition ON
there is no relay for the heater fan it's a 15 amp fuse and is on the accessories circuit. the reostat is responsible for all 3 speeds .with the key off there should be no voltage to the blower motor whether the fans speed fan switch is on or off. the fuse will be located in the fuse paneleither on the drivers left side in the dash or underneath the dash in the fuse block. you have a short in the harness that is under the dash and most likely it's a bad plug on the harness. your going to have to do some searching but that's where the problem short is... please rate
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
