Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Error f13 on my frigidaire oven how do i fix it
  • Maryellen Faherty Jan 26, 2013
    I have a frigidaire gallery series oven and it stopped working the top digital part displayed what looked like a half C and then when I unplugged the oven and replugged it nothing displayed at all on the top digital top, but all the top burners five of them are working, what can you suggest. Thankyou Mary.
  • Frigidaire Master
  • 12,061 Answers
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Posted on Feb 19, 2010
    New Friend:
Something wrong here, i found this part for two drastically different prices and it he part number shows two different items for that part number-please clarify. is the electric oven control part the same as a clock timer part?
http://www.lowriderblog.com/item-140417406054-Frigidaire+Clock+Timer+AP3874704+New.html
http://www.appliancepartspros.com/part_details.aspx?part_id=3874704
Posted on Jul 09, 2010
2 Suggested Answers
SOURCE:
protek480
  • 1730 Answers
SOURCE: F13 flashes on my Frigidaire electric range
F-13
Control's internal memory may have
become corrupted.
1- Press Cancel key.
2- If fault returns disconnect power, wait 30 seconds and
reapply power.
3- If the problem persists upon power-up replace the display
board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 26, 2009
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
answered on another appliance site..
https://www.justanswer.com/appliance/9dp3z-tyler-i-frigidaire-stove-with-dr-error-code-oven.html
the F13 indicates that you have an EEPROM (Electrically Erasable Programmable Read-Only Memory) error in the clock control board of the range. You can unplug/turn off breaker to the range for 1 minute and then plug/switch it back on. This too may possibly fix the DR.. maybe?!
Feb 12, 2018 | Frigidaire Ovens
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
F13 code
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
Aug 07, 2014 | Frigidaire Ovens
I HAVE A FRIDGIDAIRE STOVE AND OVEN MODEL #PLES389CC SER. #NF54421685 AND WHEN TURNING ON THE OVEN IT GIVES A F 13 CODE. WHAT COULD THAT BE?
Hi.
F13 means Bad EEPROM check, which in simple words means bad oven electronic control. The EEPROM is memory a chip mounted on the ERC board (oven control module). When the board detects that the data stored on the EEPROM is not valid you get this message.
Try disconnecting power from circuit breaker for ten minutes. If that does not work, try longer, leaving oven off for few hours. If that does not fix the problem, then the control module must be replaced.
Regards.
Ginko
May 31, 2011 | Frigidaire Ovens
I get an f13 error when turning on the broiler...
if you are confident enough turn off power to boiler and open up the electronics part, check all connections to PCB are tight and not corroded.
May 04, 2011 | Frigidaire Ovens
Im getting F13 on my oven display when trying to use it?
Sabrina I do not see an F13 Error Code for Whirlpool, Try unplugging oven for a few minutes and then plug or switch power back on from breaker and it should reset. Also send the exact model number located inside your bottom drawer door or oven door. Here are all the codes listed for Whirlpool=> Whirlpool Fault Codes You also can find your user manual here=> Whirlpool User Manuals and model number Locator's here=> Model Number Locator's I have spent a lot of time trying to help and will be happy to assist you if you have more questions, Thanks, Sea Breeze
May 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Getting an F13 error message on my stand alone professional series oven smooth top, how can this be corrected?
F13 does indicate you need to replace the electronic oven control. It means EEPROM/ Checksum error. If you have unplugged and it returns, this is a bad control board.
I hope this helps.
Apr 21, 2011 | Ovens
F-13
become corrupted.
reapply power.
board.
Sep 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Error Code F13 and door locked
press clear for five seconds if that doesn't work then power down for 30 seconds then on if that doesn't work replace the eoc
Mar 19, 2008 | Frigidaire FEB30S6D Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
8,452 people viewed this question
Top Frigidaire Ovens Experts
Craig Butler
Craig Butler
Marvin
Marvin
Bruce Denton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
