Ge Medical Systems 3 Lead Ekg / Ecg Cable 4 Datascope Mde Ge Nellcor Logo
Posted on Feb 19, 2010
GE MAC 50000 printer error
I have a MAC 5000 with a defective optical sensor. Does anyone know of a replacement sensor with long leads that would work in this system?
Medical Device Depot
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Feb 21, 2010
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
6317
Points
22
If you are talking about the patient cable.  Then yes it is available from www.medicaldevicedepot.com
2helpful
2answers
Minolta 5000 Error code COF10
this is an issue with ae sensor board pwbh board what you will need to do is check the voltage across pwb-a pj3a-3 and ground dc0.18v or less when the scanner is at the home position the exposure lamp is off and the original cover is lowered
if yes change pwb-h if no change pwb-a
Canon ipf 5000
Hi
The error indicates "Recovery system rotation count reached 50000" or "end of life". The printer has reached maximum expected printouts.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
1helpful
2answers
Ricoh aficio 1035 error code SC121
sc 121 is related to optics section of your machine.check the lamp is glowing .if so check the connection from optics to main board.
GE MAC 5000 with a printer problem
You are probally using the wrong paper. Look at the part number for the paper you are using and cross refrence that with the correct number.
GE Wireless Optical Mini Mouse Model 98793 doesn't work properly. Pointer jumps to the right constantly. I use mac, doesn't look like this mouse has any drivers and i also tried pushing both buttons,...
sir
you are thinking right. Its the manufacturing fault . There is no problem with your system.
you should replace this mouse with new one thats all u can do.
thankyou for using fixya
dont forget to rate the solution
1helpful
Minolta EP4000 Error C0b62
Hello sir;that's sorter bin problem, check the sorter bins see anyone out of track not move otherwise shift motor defect.
2answers
Help me quickly
Scanner home position sensor,faulty scanner error .Switch machine on/off if the error still show you will need a qualified tech to atted to your machine.
PLEASE HELP! Error Light blinks when powered up!
Inyadrms, Did the printer get hit or bumped around while in storage? The motor and alignment errors are bad. If you are mechanically inclined, remove the cover and look for broken parts or missing teeth on the gears. While you have the cover off, give it a good dusting
Top Ge Medical Systems Medical Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Ge Medical Systems Medical Expert? Answer questions, earn points and help others
