HP Photosmart C4240 All-In-One InkJet Printer Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
C4240 CLICKING NOISE WHWN PRINTHEADS MOVE - HP Photosmart C4240 All-In-One InkJet Printer
Anonymous
Level 3:
President:
  • Master 1,194 Answers
  • Posted on Feb 19, 2010
Anonymous
Master
Level 3:
President:
Answers
1194
Questions
Helped
307594
Points
3666
Product make unusual noise due to dust, so you need to clean your printer.
Just visit this link and perform the steps given there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01931887&cc=us&lc=en&dlc=en
Have a nice day...don't forget to rate the solution
Ford f350 auto hubs
check the fluid level may be needing topped up.
1helpful
CANNON MX330 CODE 5011 AND CLICKING NOISE IN SCANNER PART
The clicking noise is probably the scanner unable to move. Remove the scanner and check the belt is free to move by hand. Its possible some part has become dislodged and jamming the scanner. Sorry its a hands on fix.
The problem on my HP Photosmart C4240 is a loud clicking noise (like a ratchet slipping) when the printheads stop moving. The noise occurs when the head starts moving and when it stops.
hi ,
try and clean the print heads manually
and reinstall the printeads
disconnect the power cable from the back of the printer and keep pressing the power button for 20-30 seconds
follow the instructions from the below mentioned url
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867260&cc=us&lc=en&dlc=en&product=3300219
if the issue is still not resolved its a problem with the printer and if the printer is in warranty call hp ion the toll free number-1800-474-6836
hopefully this should resolve the issue
thanks
regards
HAMID
Whwn i turn the heat all the way up loud clicking noise if turned lower noise stops what could this be notfan
I think your talking about the heater fan? If you hear more noise as you increase the blower speed, there is something in the squirl cage or a problem with the blower motor itself. Leaves, paper or something lite on the pass side floor, it will get sucked into the recirculation duct,causing a noise.Remove the blower motor and clean out any debris, and inspect the squirl cage and turn the motor by hand to see if you hear any noise
HP Photosmart C4240 all in one keeps stating in que and won't print
I had the same problem. Make sure the usb cable is plugged in properly connected from the computer to the printer
How do I refill my # 75 & # 99 ink cartrige for c4240 HP photo smart printer?
visit this link & get an idea of refilled cartridges for sale plus you will also get ishops same no. bu witten as COMPATIBLE. If you are frequent user of this printer then you could go in for refilled pack, but if you use it occassionaly then better to replace with original ink cartridge
http://www.inkplustoner.com/photosmart-series-photosmart-c4240-c-28_32_1999_5031.html
....................................sodeep
1helpful
Printhead problems
It's likely that your printheads have just been knocked about a bit when you cleared the jam and all you need to do is to remove and then reseat them again properly...
Try this:
  • Open the main printer lid (not the scanner) :-)
  • wait for the printer LED to show the message about replacing printheads
  • Press and hold the OK button for 5+ seconds.
  • Wait for the printheads to move into the replacement position and wait 5 seconds more to be sure the printer isn't messing with you as sometimes it likes to move a bit more before it settles.
  • Lift the blue lid clear
  • Remove the printheads one at a time and check for any ink smear on the back part where a circuit board sits... This may need some gentle cleaning with a cotton bud
  • Check the contact circuit board in the actual printhead carriage (the bit where the printheads actually sit normally) and clean these with a cotton bud if these have become soiled
  • Replace the printheads in the correct slots and carefully push them into position
  • Close the blue lid and then close the printer lid
If the printheads are ok you should find that this will solve the problem and re-establish connection with the printer, cancelling the error. If not, it's possible the printhead is damaged but I'd give HP support a call first and request a replacement if you can (check the warranty on the printhead - they have this printed on them).
Hope this helps.
CLICKING NOISE
The clicking noise is the internal focus lens. The S500 and S600 are very succeptible to debris getting in the lens. Or, the focus lens was knocked out of alignment.
k24674
Grand Canyon Tech
Grand Canyon Tech
