Hard drive failure. You need to replace the hard disk drive. If under warranty, call Dell, if not go shopping:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010150380%201035915133&name=SATA%203.0Gb/s
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
now for the password
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
or
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
or
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive)
also
http://download.cnet.com/%7Bvalue=http://www.download.com/mail-passview/3000-2092_4-10466299.html The nature of password-retrieval software makes it more likely to trigger alerts from PC security. Password-retrieval software can be used maliciously, especially if someone else has access to your computer. Take care when installing and using Mail PassView is a small password-recovery tool that reveals the passwords and other account details for the following e-mail clients: Outlook Express Microsoft Outlook 2000 (POP3 and SMTP Accounts only) Microsoft Outlook 2002/2003 (POP3, IMAP, HTTP and SMTP Accounts) IncrediMail Eudora Netscape 6.x/7.x Mozilla Thunderbird Group Mail Free Web-based email clients. What's new in this version: Version 1.73 added 'Mark Odd/Even Rows' option, under the View menu. When it
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
