Master
- Posted on Feb 19, 2010
Re: Removed paper after paper jam and have opened all the...
Step 1
Turn the printer off and on to see if it can automatically
clear some or all of the jam. Many printers provide an error-code listing on the
front panel display for the area where the jam occurred. If your printer shows
an error code, be sure and check the printer manual to see if that identifies
the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged
paper.
Step 4
Open any other doors that give access to the printer's paper
path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in
a bag or away from light to avoid damaging it.
Step 6
jQuery(document).ready(function(){
jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_b1.jpg');
If you find a piece of jammed paper, remove it by holding it
with both hands and pulling firmly (see A). The goal is to keep the paper from
tearing. If several pieces are jammed together, try pulling out the middle piece
first to loosen the jam.
Step 7
jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_a2.jpg');
If the paper does tear, try rotating the roller gears
manually to free the paper (see B). Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any
doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is
still some paper in the printer. Reinspect the paper path.
