Question about Apple iMac G4 Desktop
Imac on boot up grey screen clicking and wurring flashing folder?
On placing install Leopard install disc on being asked where to install, no options given! I feel the hard drive is not recognised/caput! If so, is there anyway I can transfer data onto an external hard drive via usb2 cable?
    New Friend:
  • 17 Answers
If you boot from the Leopard install DVD and click Utilities on the top then Disk Utility, you may be able to see your hard drive from there. If you cannot, then something is definitely wrong with your hard drive and you would probably have to go for professional data recovery which is quite expensive (I think around $100 per GB, but I'm not sure). This is why it is SOOOO extremely important to backup your data!
Posted on Feb 20, 2010
SOURCE:
G5 stuck on white screen
Have you got the Snow Leopard boot disc that came with your machine?
Pop it in the iMac, restart the computer with the "C" key held down. That will boot the imac to the DISC. Once there go to the top menu and run a Disk Utility Repair on the hard drive.
Let me know what happens, I can help with this ;)
Nov 02, 2010 | Apple 24" iMac Desktop
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
Macbook air is locked and i don't know how to reset it?
font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
If you are referring to locked in regards to your user administrator account, all you have to do is take your Mac OS X installation disc and run the Password Reset utility to reset your password and gain access back into your Macbook Air once again.
Here are some steps you can try to resolve the issue:
BOOT TO TIGER/LEOPARD or SNOW LEOAPRD DISK-
• Place your installation Disk (Tiger, Leopard or Snow Leopard) into your drive and
allow it to load.
• Restart your Mac
• As soon as you hear the Apple Chime, press the "C" key on your keyboard
and hold it.
• You will see a White Screen, Grey Apple first, do not release the C key until you
see a Spinning gear.
• Once you see that Spinning gear, release your C key and allow the disc to
continue loading
- RESETTING ADMINISTRATOR PASSWORD-
(Works for both Mac OS X 10.4 (Tiger) and Mac OS X 10.5 (Leopard))
• When the booting to the Mac OS X disc is completed, you will now be in the
Installer environment
• Enter to next page, look up on upper left corner you should see "Installer" near
the Apple menu.
• Two spaces over you should see Utilities. Click Utilities>Reset Password.
• Select your user name from the drop down list and reset your password.
• When you are done, simply exit the Reset Password and Installer and reboot.
• At the Login window, enter your new password and you should be back into your home profile.
Let me know if this helps!
Thanks!
Regards,
-Mactechtrainer
May 11, 2010 | Apple MacBook Air
Lost password for imac 17 os x leopard 10.5
You need the os X disc.. Boot from the disc But don't install the OS again! Just click through windows far enough until you get the regular set of choices on the menu bar. One of those menus is the ultitiles and one of the choices on that menu is Reset root password..
Feb 13, 2010 | Apple iMac 17" MA199LLA Desktop
I put a snow leopard disk into a old slot loading 600 mhz IMAC running 10.4.11 with the intention of upgrading it. Now I'm getting a gray screen with flashing question mark. I didn't do anything but insert...
Try restarting and holding down the command and C keys at startup. This should eject the disk. If that doesn't work, restart with the mouse button held down. This is also to eject the CD. If it doesn't boot correctly after the CD is out, restart holding command, option, O and F. This should bring up an open firmware command prompt screen. Type in "reset-all", without the quotation marks, and press enter. This will restore the PRAM and NVRAM to factory defaults and should allow normal booting. It may take a bit longer to boot the first time after you do this.
Nov 17, 2009 | Computers & Internet
Grey screen,computer unable to read leopard disc, tried to reset pram using command option p and r with no result, difficulty ejecting leopard disc, sometimes able to get blue screen with holding down the...
I would by pass disk repair and unfortunately go straight to reinstalling Leopard. When you get icon and it asks what you wish to do you want to reinstall and safe old files. Once you reinstall leopard you will find all your old files in previous system located in hd icon.
Oct 13, 2009 | Apple iMac G5 Desktop
I locked myself out of my imac using leopard when my friend an e dell tec got in for me ithink he upgraded it to snow when in plugged it by accident and turned it back on it camer up telling me tgo restart...
1.: Find the disc that came with your iMac that says "iMac OS X Install DVD"
2.: Turn on your iMac
3.: Insert the disc into the SuperDrive
4.: Turn off your iMac
5.: Press down on the "Option" key on your keyboard, and keep it held down
6.: With your other hand, press the power button on the back of the iMac for 1-2 seconds
7.: A screen should come up with a picture of a hard drive, and a picture of a DVD
8.: Let go of the "Option" key
9.: Using your mouse, click on the arrow under the picture of a DVD
10.: Follow the on-screen instrustions, which will guide you through the process of re-installing OS X Leopard on your iMac
Sep 26, 2009 | Apple iMac 24" Desktop
20" iMac Boot
Ar this is a regular problem i get when people try to install Windows XP or Linux on Boot camp e.t.c.
What's happened is Linux has Tampered with the boot up files and now it won't be able to boot into Linux or Leopard.
What you need to do is insert you Leopard Install disk that came with you iMac Into the Disk Drive, the disk/disks are grey and may be two CDs or 1 DVD.
Restart the iMac and the moment you hear the chimes go off when it boots up, Hold down C on the keyboard. The boot disk for leopard will then boot up,
From here follow the instructions and if your lucky you may be able to upgrade, if not, go through the system utility and repair disk permissions e.t.c.
If nothing works, You will have to do a clean install,
But you may be able to recover a thew images and mp3 files with a great bit of software i like to use, http://www.prosofteng.com/products/data_rescue.php
You do have to pay for it, and you will need to install it on macbook e.t.c. if you have one in order for it to work If your confused there is a number of guides out there on that website or on google
Hope i have been of any help
Regards
Jul 28, 2009 | Apple iMac G5 Desktop
Can,t get imac G5 W Tiger to Boot all the way to desktop.Turns on,I get,Taa Daa sound,then just folder w flashing question mark.?How do I access Bios?
Hi, You need a Tiger or Leopard installation disk. Then You start up the system holding down "C" instead of installing you start the "disk utillity" and repair it.
You can access singel user mode by starting up the system holding down command + S.
/Per
Mar 23, 2009 | Apple iMac G5 Desktop
Apple iMac G4 Desktop Logo
385 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
