Nokia 3110 Cellular Phone Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Restart my 3110c nokia phone how to format my phone with install any software
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
633
Points
14
My nokia 3110 is not starting upp.whenever i try to switch on the phone a light blinks 3-4 times and than again it switch off.. so what should i do
Anonymous
Level 1:
  • Posted on Feb 25, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
633
Points
My 3110c phone switch on that time dislay this word
phone resturict code
undo code
how to slove pls give sloution
Anonymous
Level 2:
New Friend:
  • Expert 69 Answers
  • Posted on Feb 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
69
Questions
0
Helped
11843
Points
158
Dial *#7780# and then enter security code 12345
please this post.
1helpful
More often my nokia 3110c phone restarted or switched off, calucalator had deleted and also inbox msgs ware deleted
you will have to get your nokia flashed from a mobile repair shop.
flashing means installing a fresh software and formating the phone.
7helpful
3answers
Reformat in hand 3110c
Formating the mobile phones is known as flash
To flash your Nokia 3110c you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you Don't forget to rate
13helpful
3answers
I am getting "Invalid Application"
DOWNLOAD THE APPLICATION TO YOUR PC
AND THEN INSTALL USING NOKIA PC SUITE
20helpful
5answers
Hang and restart
how to be format nokia 3110c
How to reformat nokia 3110c ? it begings when sudendy restart then there are file and folders apear with Mb size but no files inside..help
well u can reformat ur phone after downloading Nokia software updater from Nokia website.instal it to ur pc, den connect ur phone wid pc and update ur phone wid Online connection on.
But it would not completely format ur phone..For complete formatting u hv to visit customer care..
Thanks.
6helpful
2answers
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
12helpful
4answers
Formatting internal memory of nokia 3110c
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Cause 5 - MP3 files
80helpful
5answers
22helpful
5answers
NOKIA 3110C DOES'NT WORK WITH MEMORY CARD
Dear sir,
I have Nokia 3110c mobile.When i was insert memory card(micro sd 1gp),it was continuously restarting.So please give some solution.
99helpful
8answers
Software
nokia 3110 classic software
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
