1) You have problem with LUBE deck belt, this happen because the lack of maintenance, you must lube EVERY week, use 100% silicone lube. Maybe you have WORN deck belt,
2) LUBE the rollers bearing too, use wd-40
3) Test the drive belt motor, see for break, or worn, and replace or tension by 1/4"
4) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for help and troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board controllers is faulty. God bless you. see the block diagram attached.
