It sounds like your starter is drawing current the solenoid inside the starter is most likely your problem have it checked out at any local autozone thanx Chris
start engine with engine running disconnet the neg terminal on the battery if engine keeps going then its a battery fault if engine stops straight away then its a alternator fault
Is your battery genuine?,.if yes! try to buy a new genuine toshiba charger,.. because some laptops don't work or hangup if you use a generic charger,..
yes its possible it has a factory immobiliser ,from around 94 but as its a take off of a merc then yes its highly possible it has alarm ....sorry if it has dealer only
i am in the process right now, and am having difficulty. the battery that was purchased does not fit properly; vent tube side would face belt side if terminals are aligned. to access removal of old battery, though, i took of the side panel, removed/unscrewed where owner's manual/tools sit. then, just disconneted bolts from terminals and slid it out.
i had the same situation
this happens when you dont turn off your t20 after you disconnet it from your pc
IRIVERS T2O PROBLEM IS THAT IT AUTOMATICALY TURNS ON EVERY TIME YOU DISCONNET IT FROM PC AND IF YOU DONT TURN IT OFF AFTER THIS - IT FROZES
it wont connect to pc after this happens so you have to wait ussualy (~12 hours) until the battery runs low, so after this has happened wait and then after some time try to press play button (to turn it on) and if the battery is dead - it will show LOW BATTERY sign and then you can connect it to your pc again normaly!
hope this will help
