Contributor
- Posted on Mar 25, 2010
Re: My amp turns off when i turn it up, the low volt...
Check ur batterry post make sure there nice and tight i have the same amp same problem make sure the ground wire going to the batterry is clean and tight
does it cut off when rpm's on car is up, or just at idle, try turning it up and holding rpm's to 3500. I added a cap to my setup just to monitor voltage drop. also, what subs are you running, make sure load is not under 1.5 ohms, use a multimeter for checking both dc voltage and ohms. make sure power is off too subs when checking ohms.
