Mitsubishi WD-65731 65" HDTV Logo
Posted on Feb 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 57" mitsubishi 1080 dlp tv and it has a white dot on the picturewhat is it and how to fix it.thanks terry
Azrael SRL
Level 3:
  • Mitsubishi Master 11,800 Answers
  • Posted on Feb 18, 2010
Azrael SRL
Mitsubishi Master
Level 3:
Answers
11800
Questions
0
Helped
2566665
Points
35672
If the dot is there whatever the image source / input are you using then the defect is in the DLP panel - the mirrors from the panel corresponding that dot aren't commanded anymore. It can't be fixed, the panel must be replaced. It will be expensive.
Is there a recall on the mitsubishi dlp chip wd-65735 and are they replacing them free
Nope,,,White dots, white snow or sparkling stars on your DLP TV mean only one thing - a worn out DMD chip. The white dot syndrome seems to happen when the DLP TVshave been in use anywhere from two to five years - usually when the warranty has expired
Certain brands seem more vulnerable than others to the white dot syndrome. Samsung and Mitsubishi DLP TVs have been plagued with the problems for several years now. Sony and JVC choose to take the TVs set off the market in response to complaints from disgruntled owners.
If you read the various forums offering solutions, you'll see customers being given quotes of $600 and upwards for solving the white spot syndrome or replacing the DMD DLP chip. Fortunately, there are companies offering the offering the DLP chip for under $230 if you want to fix it.
How do I fix white dots on my Mitsubishi DLP TV?
Hello. Please call Mitsubishi! Some models the DLP chip is covered under warranty, and all you have to do is pay labor costs, our shop charges $200.
White dots appear on screen
Sounds like your DLP chi is faulty
1helpful
2answers
White death DLP TV
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP.
http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/
or for Mitsubishi
http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
3helpful
8helpful
3answers
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Hi I have a Mitsubishi DLP TV WD-65733, and two days ago a whit dot appears ont the screen and now there are two white dots. How can I fix this?
icfghost,
Your light engine is failing. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which should help you get the parts and remove and replace the bad unit.
Thanks for using FixYa and for the great rating.
hardrocko
1helpful
White dots started appearing on screen a few months ago now there are dozens of them it is a 73 in 1080 dlp mitsubishi ist it worth fixing it is 3 years old
This is a known issue for that brand check your model number and see how much the part costs probably a DMD board.
Thanks,
Michael
What Causes the white dots on a DLP Mitsubishi tv?
the white dots (sometimes you get black ones too) are caused by a faulty DLP chip. you can find the replacement for your TV at the following website:
http://www.shopjimmy.com/dlp-chips/
9helpful
3answers
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
