This is most likely a motor brush problem and this is common with the Cadiz and other large scooters that use a dipole motor. You will need to remove the motor brushes and blow out the carbon dust with compressed air. Inspect the brushes and replace them if they are extensively worn or if their is any evidence of heat damage. This should be part of an annual service which is necessary if the scooter is used daily or heavily. New brushes can be purchased from eBay for around £10 for a pair. Only use the genuine brushes (they should have a number 43 stamped on them)This is most likely a motor brush problem and this is common with the Cadiz and other large scooters that use a dipole motor. You will need to remove the motor brushes and blow out the carbon dust with compressed air. Inspect the brushes and replace them if they are extensively worn or if their is any evidence of heat damage. This should be part of an annual service which is necessary if the scooter is used daily or heavily. New brushes can be purchased from eBay for around £10 for a pair. Only use the genuine brushes (they should have a number 43 stamped on them)
You can't post conmments that contain an email address.
hi Vic, there a little black board under the tiller part , it got a ribbon cable to it so take care if looking at it , there's a fault with the circult..
I am not sure this is the correct manual for your scooter; however I did a number of searches and came up with this manual form three different sources:
