Does anything show up on the display? Like 'No Cassette' or 'End Tape'?
Are you using a foot control? Does the tape move when pressing the buttons on the machine itself? Is the foot control plugged into the side of the machine (and NOT the back)?
Hi, Does the tape move when you press rewind or fast forward. If the tape moves for a few seconds then bleeps it sound like a sensor problem. If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward. Hope this helps.
Hello Your unit needs to be send for service to be fix you can try to Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem they will service your unit
If you press and hold the 'Conf' button, the machine will record using it's built-in mic (located on the right-hand side of the machine, closer to the front). It is probably recommended to get a microphone that plugs into the machine for better recording quality. Depending on what you're recording, you could get a handheld microphone or a telephone record adapter that plugs into your phone and the back of the 3750 (press and hold 'Tel Rec' to use that).
Is this a standard-size cassette unit? Is the model number a 2740 or 2750? When you first plug the power in, does the machine make two clicking noises? Does the display show 'CAS' or 'No Cassette'?
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
If it does this with all tapes, there is a small "no-cassette" switch at the back of the cassette compartment. The switch may be broken, dirty or out of adjustment. When you open the cassette door you should be able to see the switch tab. Push it in just a bit to see if the No Tape indicator goes out.
On the right-hand side of the unit, there are two buttons with on/off positions. Both the Speaker and VOX options should be in the off position. When VOX is turned on, it only records when it monitors a level of noise. I do not have it turned on ever.
