Fisher and Paykel GWL11 Top Load Washer Logo
Posted on Feb 18, 2010
Reset Fisher and Paykel washing machine
How do you reset the washing machine? Mine gets part way through the first cycle and beeps continuosly. You have to turn it off and restart it.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
9460
Points
20
HOw to reset the Fisher Paykel machine. Mine one keyborad working but machine doesn't function. Where is reset button please?
Fisher and paykel washing machine board burnt out.. I've replaced it and lights 1 & 8 are on. Is red and the other is green and it beeps
power it off at the mains
hold in usually either the menu button or power on {check out google the exact model }
then apply the mains power
and wait and hold for 15 seconds let go
this will reset the board and clear any faults detections from before {where it came from}
all machines are different in the way reset it applied
some even rotate the program selector back to where they failed
then you can stop it drain it and wait till it opens and then start a fresh cycle too see if the fault is clear
Last cycle completed, maching beeped and washing taken out. Machine light is on rinse cycle and beeps will not reset to start new load.
Hi just read your posting.From the information in your posting you mentioned that the rinse light is on when the machine is beeping.Starting from the left to right on the wash progress lights which lights are lit when the machine is beeping,Is it the 1st and 6th or the 3rd and 7th etc?Please reply with this additional information and i am sure i can help you rectify your machine.Looking forward to your reply.
Our Fisher Paykel start beeping after the first wash cycle. The first wash light is off and the cold and hot lights blink. Book says must be a water intake issue, but I replaced two intake faucets and...
When you replaced the faucets if you mean the solonoids they must be twelve volt.But From left to right tell us what lights are on for a fault code diagnosis.Cheers.
Machine stops and will not move to next cycle--spin
Sounds like it it not recognizing that the lid is closed, could be a bad lid switch.
Fisher pakel water saver washer non stop beeping in cycle
hi any of these beeps that occur outside normal operation are normally indicating an error picked up by the processor and most times requires service you could try switching off machine and unpluging it for a couple of minutes then plug it back in ,this ill ussually reset any memery faults if they are able tobe reset
cheers grant
2answers
Doesn`t finish cycle
Thanks for the information !
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
