Question about Jandy PUMP SHAFT SEAL - FITS PUMPS
Jandt filter leak
I have a jandy filter that is six years old it is leaking and the company that installed my pool and equipment said the entire jandy filter needed to be replaced. is it possible to repair the leaking vs replacing the entire filter
  • Pete May 11, 2010
    Where is it leaking?
  • 366 Answers
It depends, if it's leaking due to a crack on a structural part of the filter such as the tank itself, then yes, the entire tank will need replaced.
Posted on Feb 20, 2010
SOURCE:
Have a Jandy Stealth pump. In the morning the pump does not prime. I have to remove, replace lid and then turn it on it works as it should.
Sounds like an air leak in the system. If you have a media filter make sure that the back wash line is not leaking or look for leaks in plumbing.
Jan 12, 2017 | Jandy Pool & Spa
I have an AquaTools filter that is approximately 10 yrs old. I had a leak from the backwash. I replaced it with a Hayward spider gasket but the gasket seemed a bit small and water is still leaking out. ...
it's tight to turn because spider gasket is not correct size , if correct new old stock gasket cant be found then entire body of muliport valve needs to be replaced with modern equivelent
this will involve draining down water from entire filter section as glue needed to install doesnt like wet pipes too much and wont stick well leading to leaks , if your not 100%comfortable in doing this your self then a trusted pool service co needs be contacted ,plus who knows maybe they got the org gasket you need?
May 27, 2014 | Pentair Pac-Fab 2" DE Filter Multiport...
Jandt 8265 waiting, will not connect
make sure batteries are good if good make sure closer of pool reconnecter red 4 pin connector also they come programmed on channel 5 if you need to change chnnel its in your book if you dont have book go to zodiac web site for manual
Sep 02, 2013 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Water flows out the condensation tube even when the heater is not runiing causing the pool to leak down. The heater is 4 years old. Thank you.
It sounds like there is a leak in your system. The condensation tube is to drain off the water because one of the byproduct of combustion is water and it condenses on the heat exchanger. Since it is only 4 years old it might be under warrantee for this issue. The problem might be simple but could be very expensive if the heat exchanger has a leak.
Aug 06, 2011 | Jandy Laars Hi - E2 350,000 Btu Heater
Noticed water leaking a lot from bottom of unit. Looked like a pretty good leak. Unit is 9 years old. Leaks when Pump is running
More than likely the heat exchanger. Has the pH and Total Alkalinity been low? Check the Pressure/Temp relief valve, thermostat probe, high limit switches, etc. first though...
Jun 12, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Our Jandy Rayvac is around 5 years old...has been working fine. Recently it started going in circles and won't clean the entire pool just a circular pattern. Do you think I need to replace the swivels?
probably not...usually, this is just a dirty filter...i f that's clean, then try cleaning the propulsion jets w/a paper clip...also, if you've modified/cut away any hose over the years, that can screw up the geometry too and cause circling...also, check for lineleaks and overall pressure (~20psi usually, go higher if needed to avoid circling), and be sure the backup valve turns off when not backing up...if overall pressure is too low due to leaks, etc., it will circle.
May 11, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
May 02, 2010 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Apr 30, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
My Heater is leaking water from underneath.
yes you can replace the core but you should check all the other components to be sure the chlorine hasn,t destroyed them.
Feb 21, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy PUMP SHAFT SEAL - FITS  PUMPS Logo
224 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
