Dont need a code just get a toggle switch and hook that to the yellow/blue wire and with the other side ground to the small lil screw where you will see a small lil short wire and then all u have to do is fallow the screen with the e brake but just flip the switch 3 times with the whole one sec then off for 3 sec then on
if this is about the dvd player dont even do that just hook up the pink wire/brake wire to your radio ground
yes, when in video 1 mode use remote: Press (esc)(esc)7714(ok) that will take care of it. or (esc)(esc)7197(ok) a master reset is (esc)(esc)19750601(ok) window main screen (esc)(esc)9702(ok) hope this helps!
yes, First, and you must do this or it wont work, ground the brake wire and leave it grounded permenantly. Then while in video 1 mode (blue screen) use remote: Press (esc)(esc)7714(ok) that will take care of it. or (esc)(esc)7197(ok) a master reset is (esc)(esc)19750601(ok) window main screen (esc)(esc)9702(ok) Now you can enjoy video while in motion (AT YOUR OWN RISK)
That toggle switch way is about getto and your gonna have to drill a hole in your dash for the switch...yuk!
Yes,
use remote:
hope this helps!
Www.ztwshop.com http://www.ztwshop.com/
Yes, First, and you must do this or it wont work, you ground the brake wire and leave it grounded. Then while in video 1 mode (blue screen) use remote: Press (esc)(esc)7714(ok) that will take care of it. or (esc)(esc)7197(ok) a master reset is (esc)(esc)19750601(ok) window main screen (esc)(esc)9702(ok) Now you can enjoy your video while in motion (AT YOUR OWN RISK)
I've tried this method several times and it does not work. The only thing this has done was that it left me with the problem of my screen now refusing to close
