Need soft ware for model T-6000U. Can I download this for free please ?
I also have a Digipro T-6000U, works perfect on my XP machine. But even with the drivers from UC-Logic, I could not get it to work properly with Windows 7 Ultimate 64bit. I tried everything I could think of, no luck... until tonight!!!
I downloaded drivers for a Joy Graphic Tablet (Tablet 12000U / 8000U/ 6000U/4000U) from Waltop Corp. Waltop Corp The best digitizer with battery free pen Support
Here's what I did:
1- Unplugged the tablet and uninstalled the old drivers in control panel.
2- Download the driver file for windows 64bit and extract it.
3- Run the setup then reboot your computer.
4- Once Windows is back up and running, plug your tablet in and let windows find it.
5- From the system Tray, click on the Pen Pad icon and setup the pen the way you want it. You can also setup the Hot Keys from there too. The "Pen Offset Value" was selected to "Auto Settings" by default. I had to unselect it and run the Adjustment on it in order for my pen to track my full display area.
I now have my Digipro T-6000U working on my Win 7 64bit machine.
I hope this helps other people out there.
Drivers for DigiPro T-6000U graphics tablet,
http://www.uc-logic.com/download/download_driver.htm
The download file is in ZIP form.
(ZIP files are used to send a file that is large in size, more easily over the internet)
When the small window comes up, Left-click on the empty circle to the left of - Save File
Another small window should come up, with a download progress bar.
Let the file download all the way.
Where will the file go?
If you have your downloads set to save to your My Documents folder, (Documents for Vista), it will go there. (Start>My Documents)
It may go to a sub-folder within My Documents called Downloads.
If you do Not have your downloads set to save to your My Documents folder, this file will go to your desktop screen.
When you see the file - Driver 5.02.zip
double-click right on it.
The Installation Wizard will open up.
Go to the upper far left of the window, and left-click on - Extract All Files
This is the Instruction Manual. It's in PDF file form,
http://www.uc-logic.com/download/instructions.htm
Which tablet did you receive?
http://lifewithhammy.wordpress.com/2009/07/29/digipro-t-6000u-6x4-5-usb-graphics-tablet-review/
