My acer aspire 5100 laptop powers up emitting two short beeps, but the screen remains black/blank. no text comes on but the laptop stays powered up. Ive been told its probably the graphics. but because its all on the motherboard its not worth fixing because it would cost too much.i need a second opinion!
if you have power it's not the power supply. It sound like the screen maybe gone on your laptop. Have tried hooking up a monitor to your laptop to see if the screen will come up?
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
That is telling you there is a hardware problem, you will need to contact the manufacturer to see about a repair (it may still be under warranty), or a local computer repair shop.
Standard Original IBM POST Error Codes1 short beep
Normal POST - system is ok
2 short beeps
POST Error - error code shown on screen
No beep
Power supply or system board problem
Continuous beep
Power supply, system board, or keyboardproblem
Repeating short beeps
1 long, 1 short beep
System board problem
1 long, 2 short beeps
Display adapter problem (MDA, CGA)
1 long, 3 short beeps
Enhanced Graphics Adapter (EGA)
3 long beeps
3270 keyboard card
so it sounds like your video card is having trouble
2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive
now, start the process
STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in!
STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons
release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart.
this works on me... good luck.. and i hope it will help you.....
The bios beep codes indicate the video card is not working, so you won't see anything on the screen.
Your video card is either dead, or is not contacting the board correctly.
If you are keen to open it up I will offer instructions to assist you. But in reality, your safest bet is to take it to a laptop shop and get them to do it. There are a lot of tiny screws in these things.
