If the product is as pictured, (two single pole switches in the space of a single switch), then it probably has 4 terminal screws (in addition to the ground). Look closely at the terminals on one side of the switch. If two terminal screws are brass colored and two are silver colored, look on the brass colored side. There is probably a strip of metal that connects the two terminals together - this is what is keeping your light "on". You need to move one of these wires to the other side of the switch. I assume the other switch operates OK and you only have 3 wires (besides the ground).
On the other hand, if you have a total of 4 wires, then one of the wires is probably for powering something else (an outlet, or even another switch that is not supposed to be controlled by this switch). You will probably find that other device is currently being controlled by this switch. You will have to swap two wires, but without more info I can't tell you which ones.
If you found this helpful, please vote.
