First you have to create partition.You need at least two partition. One in which you intall Xp and other for win 7. WARNIG BACK UP YOUR DATA BEFORE THIS.*(You can create partion by any hard drive manager you can make a hard drive partition in control panel>administrative tool>create & manage hard drive partition) Now install xp first in one partition. If you have pre installed then avoid this step. Now install Win 7 in another partition. After you restart the machine will ask to chose your os. & just select the required OS.
If any problem appears then just put win XP disk & repair it.
You cant install win Xp after windows 7. You have to format win 7 before installing Xp. Commiting any of trick or Tweak you need to backup your data in another HD partition WARNIG BACK UP YOUR DATA
chances are, the drivers installed may not be the correct one that matches the components of your system. If you still have Windows 7, check Device Manager to see which device are not installed properly, then look for the correct Win 7 drivers for thos devices from Acer. If in case there are not Win 7 drivers for some devices, try to look for Win vista compatible drivers as they will usually work for Win 7 as well. Hope this helps and your rating/comment if this helps would be appreciated
Try to re-install 2 Operating systems use this order, 1,Install windows XP by booting the XP cd, 2,and then install Win 7 by booting from Win 7 cd. Then while you restart computer there will be a prompt menu asking to select OS to start. Thanks
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
