Vacuums Logo
Posted on Feb 18, 2010
Fairly new Platinum series Hoover Max extract wont turn on
Fairly new . Will not turn on. What could be wrong with it? tried several outlets and nothing happens.
  • Anonymous Mar 16, 2014
    Wheels don't turn
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1391
Points
8
I have the same problem. Fairly new machine, only been used a handful of times and now it wont turn on.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1391
Points
Fairly new platinum hoover max extract rug shampooer won't turn on.
I have a Hoover max extract 77 and the brushes won't turn. I bought a new turbine but brushes still won't turn.
Make sure brushes spin freely when not in the machine. Make sure filter screen is clean.
My Hoover max extract 77 will not turn on why
The power switch's in those machines are crap. You can take the handle assembly out and replace switch with a new one. When took apart check voltage at switch to make sure you have power there. If no power, replace cord
I’m happy to assist further over the phone at https://www.6ya.com/expert/matt_0c9009be7d775298
Hoover max extract 77 manual
Hi! Follow the link below to view the manual for the FH50240. Hope this helps!
http://hoover.com/file/611/
Hoover max extract V clean water leaking
get a new clean water tank or a seal to put on it from hoover.com/vacuumparts
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
1helpful
I can't get my Hoover max extract platinum to
First this is complicated to diagnose with it not being in front of me. Where i would start if i were you is make sure it is all together correctly or simply take it apart and put it back together make sure all is there and seated proper and try it again also if you feel no resistance or hear no clicking sound from the on switch it just may be bad.
6helpful
4answers
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
