Mitac Mio  P550 GPS Receiver Logo
Anonymous Posted on Feb 18, 2010
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it will be OK.
Anonymous
Level 1:
  • Contributor 68 Answers
  • Posted on Feb 20, 2010
Anonymous
Contributor
Level 1:
Answers
68
Questions
0
Helped
19718
Points
77
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Testimonial: "Advice was helpful thanks"
1helpful
I need to find a ac/dc charger for a Defiant Flashlight Model 800-2701D Can you help??
This flashlight is sold by Home Depot, and it is possible that you might be able to find a name-brand exact replacement charger there. However, you almost certainly can find a replacement charger elsewhere for less money.
Looking at a picture of the light and its power adapter, it appears that the light has a standard barrel charging port. A dollar store or "Dollar Plus" store is likely to sell inexpensive multi-voltage universal chargers that will fit this light and get you back in business for under $5.
When fitting a non-OEM charger to your light, make sure that you've set proper polarity and input voltage for your device, or else you may damage it in charging. Many devices specify voltage and polarity right on the device, molded into the case or on a small sticker. That makes this process super-easy. Otherwise, you may have to head down to a Home Depot and peek at one of these lights in its box to read the voltage output off the stock charger. The odds are pretty good that it'll be putting out 12 volts, but I won't guarantee that by any means--input may be 6v or even 4.5 volts, though those are much less common in lights of this type.
MIO P550
oprn that folder and there you find the licence detail and fill in the licence detail and then turn off and turn on device and it will be done.
tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 • Cameras
I have mio s600 and during the travel the car charger has stopped working, so the navigation automatically started to use it's one battery. After I pulled out the charger, and sticked it in again,
If you are using the lighter plug for charging it may have a fuse inside the plug itself the plugs into the lighter socket,,,,,look for a fuse there or if have a volt meter check for voltage reaching the unit when plugged that way If voltage is good to the unit from the car source the battery may be bad, either not getting a voltage for charging or battery not holding a charge.
Dec 07, 2012 • GPS
2answers
I lost my Philips Coolskin 7775X shaver charger.
philips norelco 4222-039-10972 adapter charging cord for electric shaver norelco 7775x power cord replacement parts.
1helpful
Lost ac adaptor
well look on the player it self should say some sort a input voltage they all very then goto radio shack or dollar store find that style charger watch for ac and dc voltage good luck
2helpful
MIO p550 will not turn on
hi
i think you must know the difference between hard and soft reset.
soft reset is the small hole you put the edge of your stylus to reset the device without erasing anything. (software restart)
hard reset (hardware restore) is:
switch the on/off slider button to OFF. keep the joystik pushed UP and without leaving the joystick slide the from OFF to ON and wait about 30 seconds.
do all that while connected to the power charge. I'd prefer you do that with a wall charger, and not with a USB cable connected to your computer (we dont like this charging state from USB ports)
let me know what happened after that. if possible, upload a video showing us what you did.
thanks
Gery
www.nextlab.co.il
Mio fails to charge and doesn't work
it may be a battery problem, USB charger problem or something. Why not call them and ask? They are nice (you can tell them I told you so). Look up the number at
http://www.mio-tech.be/EN/support/support-overview.php
Hope it works
2helpful
5answers
Where can I get a new charger, I lost mine
You can try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger for the TruTech PVS12701.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701. (am guessing crown type center positive, pls confirm with the store. It may also help to bring along the unit when doing the purchase over the counter)
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Top Mitac GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Mitac GPS Expert? Answer questions, earn points and help others
