Cooktops Logo
Posted on Feb 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Alarm code FC and F7, everyting works but the alarm keep come back.
Anonymous
Level 2:
  • Expert 230 Answers
  • Posted on Feb 18, 2010
Anonymous
Expert
Level 2:
Answers
230
Questions
8
Helped
81022
Points
693
Hi There
I have found the code for you and hope help this helps out.
F7 - E1 Common switch wire is defective Common wire (+5VDC) to latch switch, and to door switch is shorted to chassis ground or neutral. A double oven will have two of each switch and one common wire.
1. Check connections at control and at the latch switch and door switch.
2. If all connections are good, then check the individual switches as outlined for the F5 failure. 2 Digit Failure CodesThank You for writing to Fix Ya.
Best Regards Richard
1helpful
What does F1 mean
The Fault Code/s will show up in the appliance Display
F0 - No Alarm Signal
Replace Main Electronic Control
F1 - Door will not Lock
Check door lock. Is Door Lock Getting Power
F2 - Door will not Un-Lock
Check door lock. Is Door Lock Getting Power Supply? Check Control Thermostat
F3 - Self Test Error
Disconnect Appliance from Mains Supply, Wait 5 Minutes and then Reconnect to Mains Supply
F4 - Shorted or Open Circuit Oven Temperature Sensor
Replace Oven Temperature Sensor, Check Sensor Harness Connection between Sensor and Control Unit
F5 - Relay Contacts Failed - Sticking
F6 - Power Board Temperature Too High
Check Correctly Installed, Check Cooling Fan Assembly, Ducting and Airways
F7 - Incorrect Polarity - Mains Supply
Check Mains Connection - Live & Neutral round the wrong way
F8 - Power Supply to Interface Problem
Check Wiring Harness, Replace Main Electronic Control
F9 - Procesor is Auto Resetting
1helpful
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Burning smell from LG oven
Hi Mike Plante, I read your problem and would be very appreciative if you can share the solution that you eventually found, as my LG unit has experienced this exact problem after the same repairs were made. Please post an additional comment on the website. Thanks, Jeff
1helpful
Jenn- Air cook top oven sve47500b has error # F7 and the oven will not work
F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Spilled liquid down inside knobs- alarm sound has finally stopped, but the ignitors continue to click. any suggestions?
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 12, 2010 • GE Cooktops
1helpful
Message f 7
Hi There
I found the fault codes for you and i hope this will help you.Let me know when you can.
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick buttonThank you for writing to fix ya.
Best regards Richard
1helpful
Why the oven want come on ?
check the starter. the piolet!! if eletric check plug wire and see if the outlet works
1helpful
F7 Error
This error happens if a function (key) is stuck. Usually the one that is used most often or the one that someone poked using something pointed.
Change the touch pad if it is separate from the clock (ERC or EOC) or change the whole clock if they are one unit
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
