Euro-Pro 7500XH Mechanical Sewing Machine Logo
Posted on Feb 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying free motion quilting on my europro 7500 but fabric does not move freely even though I have attached the plate to cover the feed dog and the darning foot. Can you help. Am I missing another step
Anonymous
Level 3:
Genius:
  • Master 1,116 Answers
  • Posted on Feb 20, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1116
Questions
0
Helped
371597
Points
3174
It sounds like you are doing as you should.
If the darning foot is not "springy" enough and is holding down too firmly, you might look for a "hopping" foot.
I use the Supreme Slider and gloves to help me better move the quilt.
2answers
Is an Elna 2006 sewing machine capable of free motion quilting. The feed dog doesn't lower but I read you can use the darning plate to cover the feed dog- What should I set my stitch length at?
Can I Free Motion Quilt on a Regular Sewing Machine? By National Quilters Circle
Yes
https://www.nationalquilterscircle.com/article/can-i-free-motion-quilt-on-a-regular-sewing-machine/
How to Stitch the Perfect Stitch Length for Quilting
JULY 28, 2020
Today’s Topic: How to Stitch the Perfect Stitch Length for Quilting
https://lorikennedyquilts.com/how-to-stitch-the-perfect-stitch-length-for-quilting/
How do I set the Husqvarna 300 sewing machine to do free motion embroidery. Do I need the embroidery attachment and get the machine to embroider with or with out the card
You can do embroidery or you can do free motion. If you're quilting a quilt sandwich (fabric, batting, backing fabric), you probably want to do free motion quilting. Embroidery would work better on fabric (with a stabilizer) but without the batting and backing fabric.
For free motion, you want a free motion foot--your machine's manufacturer probably provided one in the accessory kit (called a darning foot) or there are many generic free motion feet available for purchase (ie Big Foot quilting foot...). The BIG difference with a darning foot or free motion foot is that the shank is shorter than other presser feet because there needs to extra space between the presser foot and the needle plate so the quilter can easily manipulate the fabric. Usually, free motion quilters will drop the feed dogs to avoid feed dog interference with the fabric's movement, however, some quilters don't drop the feed dogs--just whatever works best for you and your machine. In addition, I use a Supreme Slider on the sewing machine surface--a silicone mat that provides a slick surface to help the fabric move.
There are a lot of web sites and video tutorials on free motion quilting. Take some time to watch them and then practice, practice, practice! It's an acquired skill so the more you practice, the better you will be.
Pfaff 113 want to free motion quilt the foot will not allow me to se. I even took the screw for adjusting preasure all the way out and it still has too much preassure
Sounds like perhaps you have the incorrect foot. Did you perhaps purchase a quilting foot (used for piecing)? A free motion foot is actually shorter in height so it will not contact the feed dogs or needle plate. It is this added space that allows the fabric to be moved freely under the foot. Also, be sure to drop the feed dogs.
Open Toe Free Motion Spring Foot
Open Toe Free Motion Foot
Pfaff 113 free motion foot Google Search
If the presser foot is still too long, perhaps the shank is not correct for your machine. Sorry, am unable to locate information re your particular model.
Sewing Machine Feet
How do I set up my Janome 1600p-qc for free motion quilting?
You will need a darning foot or free motion quilting foot for your machine (these feet are shorter than the regular feet which allows space between the foot and the needle plate to manually manipulate your fabric). Then drop the feed dogs and, if your machine does not have that capability, there should be a cover plate included with your machine that snaps over the feed dogs. Install a brand new needle in your machine, set it for a straight stitch, and test the stitch. Sometimes, the upper tension needs to be loosened a bit so the bobbin thread does not poke through the top of the fabric.
Then...practice, practice, practice...
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting Beginner Tutorial 1 of 4
FWIW, I've found it helpful to use a "Supreme Slider" on the base of my machine. It is slick and allows the fabric to move easily. Special gloves are helpful too because your hand will become dry and begin to slip on the fabric. Using cheap rubber gardening gloves works for some people.
supreme slider Google Search
quilt gloves Google Search
How do I avoid breaking a needle on a 26 foot beginning a free motion project after programing the foot choice and lowering the foot?
#26 is an embroidery foot. Why are you using an embroidery foot for free motion quilting? A #24 free motion embroidery foot will work but not the #26. Try using a darning foot that is just a smidgen shorter so there is space between it and the needleplate for you to freely move the fabric. (Adding a Supreme Slider sheet to the work surface of your machine helps make the fabric glide much smoother.) A standard presser foot is made to press the fabric against the feed dogs so the feed dogs will move the fabric. When free motion quilting, you would drop the feed dogs and move the material with your hands.
Depends which model Bernina you have (new or old style presser feet), which will work on your machine. There are also many generic darning/FMQ feet available that will work on your machine.
12 BERNINA presser feet Darning foot 9 (old style)
Quilting foot 29C (new style)
Bernina 530 53 Free Motion Quilting
Top 5 Tips for Successful Free Motion Quilting WeAllSew BERNINA USAs blog...
Seven Steps to Free Motion Quilting
2answers
Does this model have a feed dog that can be lowered for free motion quilting?
    A set of feed dogs typically resembles two or three short, thin metal bars, crosscut with diagonal teeth, which move back and forth in slots in a sewing machine's needle plate. Their purpose is to pull ("feed") the fabric through themachine, in discrete steps, in-between stitches.
    Feed dogs - Wikipedia, the free encyclopedia
    https://en.wikipedia.org/wiki/Feed_dogs Wikipedia
1helpful
Why when i put the feed cover on i cant move the fabrice at all there is no room between the foot and the cover. i am trying to quilt together my quilts. thank you brenda g
I'm assuming your machine has a little plate you put over the feed dogs rather than a knob which disengages the feed dogs from moving to do free motion embroidery or something.
If this is the case there probably isn't enough room for your quilt sandwich under the foot.
You could try using a free motion embroidery foot rather than the regular foot with the feed dogs up and see if that allows you sufficient movement.
It would look like this:
It may take some practice still to get a smooth stipple if that is the effect you are going for.
You may find some other ideas on quilting websites to get around this problem or in a Yahoo group for quilters. I've only ever quilted in straight stitch using my walking foot so it feeds the quilt smoothly for me, never tried FMQ.
1helpful
Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
May 29, 2010 • Juki TL-98Q
1helpful
I am still tryin to find a way to use the machine
When you cover the feed dogs, so you can move the fabric by hand (free hand embroidrey or quilting) you need to use a spring loaded foot that more than likely didn't come with your machine. You can pick them up at most sewing stores, maybe even you fabric store. Some are called a "free motion guide foot". They use a spring that raises and lowers the foot as the machie sews, so that you can freely move the material as the machine sews.
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
